mdaien Posted March 6, 2007 Report Share Posted March 6, 2007 Hello friends,Initially I have to convert the 24V signal to 5V which I did using voltage divider circuit but now the thing is my input signal level is not decided it may vary from 15V to 24V so the question is how can I maintain 5V.My input is varying from 15V to 24V but I required 5V output.. how can I do this??????????/ ;D Quote Link to comment Share on other sites More sharing options...
jgeidl Posted March 6, 2007 Report Share Posted March 6, 2007 Try Googling 7805 voltage regulator. This device with a few caps will control the output. There are about a million circuits out there using it as it is very common.Jim Quote Link to comment Share on other sites More sharing options...
mvs sarma Posted March 6, 2007 Report Share Posted March 6, 2007 Hello friends,Initially I have to convert the 24V signal to 5V which I did using voltage divider circuit but now the thing is my input signal level is not decided it may vary from 15V to 24V so the question is how can I maintain 5V.My input is varying from 15V to 24V but I required 5V output.. how can I do this??????????/ ;Dyou didn't mention how much current you want to draw at 5V --neither you mentioned whether it is DC or AC-- iif Dc you want large currents use 7805 with adequate Hestsink.if dc and for very small currents like less than 5 mA use a high watt (2watts)resistor of say220 ohms and a 2 watt zenor diode of 5 V or 5.1V (generally availableif it is AC power you have to adopt different techniques.Sarma Quote Link to comment Share on other sites More sharing options...
