Jump to content
Electronics-Lab.com Community
12V Car outlet
harrison_c
Hi guys, I would like to know how much maximum current is there normally coming from a 12V car outlet, because I want to connect a resistor and LED with a car charger adapter.  By the way, how can we measure the maximum current from a power supply if we don't know the current limit?  Thank you.
Honford
Link to comment
Share on other sites
A car outlet? You mean a cigarette lighter socket?
It must have a fuse that will blow if wires get shorted in a crash. Then the wiring won't catch on fire. The fuse might be about 20A.
A car battery can supply hundreds of Amps to the starter motor when the engine oil and mechanics are cold in winter. Most ordinary wires in a car will catch on fire with such a high current. The fuses blow before wires catch on fire.
All power supplies have a max current rating. If it is exceeded then some power supplies blow a fuse or shut down. Other power supplies are destroyed if their max current rating is exceeded.
Link to comment
So you mean I can't hook up with a regular led and resistor to the 12V outlet (too much current), right?!  Then I will use a 9V battery to light up the led.
Just for curiosity, my last question was that if I cover up the display on the power supply, can you measure how much maximum current from the power supply?  For example, I didn't know how much current from the 12V outlet, can I measure it?
Link to comment
The load determines how much current it takes if the power supply can supply that much current.
A load that draws 25mA will draw 25mA from a little 12V battery and draw only 25ma from a huge 12V car battery.
An ordinary LED with a current-limiting resistor draws only about 25mA. The cigarette lighter socket in a car can supply up to about 20A so up to 800 LEDs can be lighted.
If you keep adding loading to the 12V outlet with a current meter showing how much current is used by the loads then when the fuse blows you will know its max current rating.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
