Jump to content
Electronics-Lab.com Community
Reading Pulse signal from a flow meter
I need to monitor the singal from a liquid flow meter in a pc application. The documentation says that the output is pulse in a "digital open collector signal." It also specifies that a 820 ohm pull-up resister must be used.  Distance will be about 20 feet. For this particular flow meter 215 pulses = 1 gallon of fluid dispensed.
I am looking for a converter, logger, or other device that will convert this information into something a pc can understand (like rs232 serial) . Can someone please point me in the right direction?
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
