Jump to content
Electronics-Lab.com Community
Sign in to follow this
Plague.Jester
Question about voltage.
[glow=green,2,300]Say I have a 9v battery, and I have a wire hooked up to it.  If I split that wire into two more wires later on, and then those two into two more wires, will there be 9v at the end of each wire, or will it be 2.25v at the end of each?  I'm sorry my questions are such elementary ones, but I just got an interest in electricity a day or two ago, and I know NOTHING on the subject.  Thanks for all your help.[/glow]
Share this post
Link to post
Share on other sites
The wiring in your house is "split" between all the outlets and lights. The voltage is the same at all of them.
The wiring in your city is "split" between all the neighbourhoods. The voltage is the same at all of them.
The same with your battery and millions of wires connected to it.
Share this post
Link to post
Wires connected to other wires don't discharge a battery. The voltage of the battery will remain the same because no energy is taken from it. A load connected across the terminals of a battery will discharge it and take energy from it.
If a wire from one terminal of the battery touches a wire from the other terminal of the battery then it is a short circuit and the battery will be quickly discharged.
A load for a battery is usually a light bulb or an electric motor.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
