Jump to content
Electronics-Lab.com Community
2 5V power source for a circuit
galapogos
I'm wondering if it's possible for a circuit to have 2 different power sources for 5V? I've seen many USB bus powered drives that normally use the USB 5V voltage to power the drive, but they often also have a DC jack. All of the ones that I've seen have both the Vusb and the Vdcjack connected to both the drive's 5V and the circuit's 5V input into the LDO regulator, i.e. both 5V sources are shorted. When an AC adapter isn't being used, this isn't a problem since there's only 1 5V source(Vusb), but when an AC adapter is used, isn't this potentially dangerous due to differences in voltage levels between the 2 5V sources, as well as 1 source overpowering the other? What are the chances of things blowing up?
Thanks.
Link to comment
Share on other sites
The voltage requirements for USB is that at worst case (longest cables, highest drain, poorest connections) there must be a minimum of 4V3 _at the device_.  If the device in question can stand to run on as little as 3V6, then a diode in series with the supply will cause problems.  A diode in series with each supply is probably how the device in question prevents supply contentions.
Link to comment
As far as I can tell, there's no switch. The circuitry for these cheap enclosures are pretty simple, and the PCB is small with very few components.
What would happen when they are shorted? Worst case, would something blow up?
Also, how's this for a solution? I'm thinking of either 2 FETs or BJTs with low Vce(sat), one for each power source, but opposite polarity. The base/gate would be controlled by the 5V from the DC jack, so that whenever there's power from the DC jack, the DC jack FET/BJT is switched on and the USB one is switched off.
Would this work or am I crazy?
Link to comment
OK, so I tested 2 of the enclosures I have here that have DC jacks. They all have 3 pins, so I assume they're switched jack. I found 2 of the pins that are shorted with a multimeter, and then I plugged in the DC jack(unconnected to the mains of course) and tested for continuity on those 2 pins again. Doh, they were still shorted.
So either the 3 pin jacks aren't actually switched jack, or the enclosure maker simply shorted the 2 on the PCB side both to GND, which means they're still shorting both power supplies rather than switching them.
Anyway, the center pin(pin 1) is positive, so the 2 pins that are shorted are GND. This contradicts what you say about "usually the positive is switched, not the ground."? Does it matter which one is switched? Would it still break the circuit if the USB's GND is disconnected from the circuit GND?
Link to comment
Hmm, I thought the adapters are pretty much standard. Is one more prevalent than the other?
Also, I don't think switching the GND would work right? Since the USB ground is from the PC, which is from the wall socket, which is where the AC adapter GND is from too, so they sorta share a common GND.
Link to comment
What about AC adapters with 3 pin plugs? Is the DC ground still isolated from the AC wall socket? Anyway, does it even matter? Will breaking the GND on the USB side cause it not to supply power to the circuit? Coz I did some googling and it seems that positive polarity AC adapters are a lot more common than negative ones, so it'd be good if I can just break the USB power by disconnecting it's GND.
Link to comment
I took the easy way out and simply placed 2 schottky diodes on the 2 voltage sources to prevent any back flow of current. It seems to work, except my voltages are down to ~4.75-4.85V. My device has a 5V tolerance of +/-5%, which puts me on a borderline case. I'm wondering if there are any low drop out schottky diodes that have a lower forward voltage? I'm currently using a Zowie MSCD202 that has a Vf of [email protected]
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
