audioguru Posted May 22, 2007 Report Posted May 22, 2007 Hi AN920,I have seen very simple class-B amplifiers (like the LM324 opamp) that do not have their bias "ridgidly controlled" (most do not have any bias) and they produce terrible crossover distortion.All the class-AB amplifiers that I have seen have a fairly small idle current of about 50mA which produces no crossover distortion, a very low level of TIM distortion and little heating. Quote
AN920 Posted May 22, 2007 Report Posted May 22, 2007 The quotation and paper refers to audio power amplifiers and not small signal op-amps. Quote
audioguru Posted May 22, 2007 Report Posted May 22, 2007 Hi AN920,I mentioned the LM324 opamp because it and its sister the dual opamp LM358 are the first low-power opamps and they use insufficient bias current in their output transistors to reduce power consumption. They are the only opamps that have horrible crossover distortion.Class-AB power amplifiers use an idle current of about 50ma to avoid crossover distortion. Quote
AN920 Posted May 22, 2007 Report Posted May 22, 2007 From another author: Randy Slone's bookEnthusiasm for class A today is often supported bya variety of misunderstandings and myths. The following list providessome major examples.1. "Crossover distortion in class B is a constant. At low listeninglevels, it becomes very prominent." This is an understandable assumption, but fortunately it is not true. The absolute level of crossover distortion decreases as the output signal level is decreased,but not in a proportional manner. The principle behind this phenomenon will be discussed later. However, the end result is only a slight increase in THD as the output level is drastically reduced.2. "Even though class A amplifiers are inefficient, they are easy todesign, and the sonic quality will be exceptional even in poorlydesigned units." In reality, a well-designed class A amplifier is aboutequal in complexity to a good class B design, and the class A amplifierwill virtually always be more expensive.3. "In comparison to class B designs, class A amplifiers sound better."A well-designed class A amplifier operating under favorable conditionscompared to a well-designed class B amplifier operating underthe same conditions will not reveal any perceivable differences. Otherwise,the human ear would have to be capable of hearing distortionlevels into the hundredths of a percent at 20 kHz. But we must be carefulto compare apples with apples. There are many poorly designedclass B amplifiers around, and their inferior performance characteristicsare readily detectable.CLASS-ABClass AB is not really a class but rather a poor marriage of both class Aand class B characteristics. It has been erroneously taught that a classAB amplifier becomes a class B amplifier when all bias is removed fromthe OPS. This is incorrect. Technically speaking, class B pertains to anOPS wherein the output devices are conducting for one-half (that is, 180degrees) of the signal cycle. In order to accomplish this action, a smallforward bias must be applied to the output devices to overcome theirinherent Vbe drop. If this forward bias is removed from a class BOPS,the output devices begin to conduct for less than 180 degrees of the signalcycle, placing the OPS closer to the category of class C than class B.Class AB pertains to a class BOPS that has been overbiased so thateach output device conducts for more than 180 degrees of the signalcycle. This was thought to improve crossover distortion through themental imagery of the output devices sliding through the crossoverregion in linear class A operation. However, what actually results is aform of crossover distortion referred to as gm doubling. That is, in the crossover region while all of the output devices are conducting simultaneously,their current gain factors are doubling (i.e., summing), creatinga severe wobble in the linearity. Both Fourier analysis and distortion analysis prove that this doubling effect causes distortionharmonics as bad as if the output devices were severely underbiased.Class AB operation also causes increased power dissipation in theOPS, decreasing efficiency and reliability. Since class AB operationprovides no advantages whatsoever and only serves to degrade linearityand create additional heat problems, it should be entirely dismissedas a "good idea that just didn't work out."CLASS BAs defined previously, class B pertains to an OPS wherein the outputdevices are biased to conduct for 180 degrees of the signal cycle. Intimes past, class B operation was referred to as push-pull operation(analogous to sourcing-sinking action), but this is a misnomer. Outputdevices in a class B OPS will source current to a load for a half-cycle,but they do not sink current during the opposite half-cycle: they arecut off. The term push-pull should be confined to class A type stages.At least 99 percent of all audio power amplifiers utilize a class BOPS. I make no apology for the fact that this book is devoted to themethodology and development of class B audio amplifiers since thatappears to be the only practical and viable choice at our current technologicallevel. Quote
audioguru Posted May 22, 2007 Report Posted May 22, 2007 I disagree. 99% of amplifiers are certainly not class-B, they are class-AB. Many of these class-AB amplifiers have extremely low distortion. If they have a very small amount of gm-doubling distortion then it is buried way down in the noise level. Quote
AN920 Posted May 22, 2007 Report Posted May 22, 2007 It is anybody's right to disagree :)Just remember that these statements are made by persons that are considered world renowned authorities on the subject and have presented numerous studies and papers to bodies like the IEEE and other professional publications. They have backed up their statements with simulation, experiments and measurements in a lab. Quote
audioguru Posted May 22, 2007 Report Posted May 22, 2007 The experts say that an amplifier with a peak output current of 5A (100W into 8 ohms) operates in class-B when one transistor conducts 180 degrees and the other transistor conducts the other 180 degrees.But most of the amplifiers made have both transistors conducting 50mA (class-AB) at idle, which is only 1% of the peak current. Then one transistor conducts for 180.5 degrees and the other transistor conducts another 180.5 degrees with only 1% of overlap. Do the experts call it class-B by mistake?Douglas Self talked about his class-B amplifier with insufficient bias, optimal bias and excessive bias. Class-B? No, the transistors conduct for more than 180 degrees each so it must be class-AB.The crossover distortion or gm-doubling distortion on these excellent amplifiers is 100dB down, much lower than other distortions and noise. It is completely inaudible. Quote
AN920 Posted May 22, 2007 Report Posted May 22, 2007 Maybe you should send an email to "Self" regarding your views, he welcomes any commentary! Quote
audioguru Posted May 22, 2007 Report Posted May 22, 2007 I wish I have all the documents written by Self. His article in Wireless World magazine probably has more details. Quote
