Jump to content
Electronics-Lab.com Community
MNA question about amplifier
walid
Have a look at the amplifier circuit shown
I want to know your views about it..... if u find any mistake in it, do point it.....
one stage to be mosfet was the requirement, so i have used the mosfet as voltage amplifier and then connected it to the power amplifier......
Thanx for any help
MNA
Link to comment
Share on other sites
The LM380 has a voltage gain of 50, so the max output from the Mosfet is only 180mV p-p. Then the supply for the Mosfet doesn't need to be 24V and the negative supply is not needed.
The Mosfet operates on an extremely low current. Its drain resistor's value is so high that it is loaded down by the 20k volume control.
The 102k resistor should be removed.
I would probably make it like this:
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
