Jump to content
Electronics-Lab.com Community
Drop amps from 25A to 8A
Soltaker
I have a 13.8V / 25A power supply that I would like to use in testing. I'm looking to drop the amps from 25A to around 8A while keeping as much voltage as possible. I've thought about using a resisitor, but it would have to be in the neighborhood of a 200W / 1.725 ohm resistor to work. Any suggestions on how to pull this off without needing a huge resistor?
Thanks in advance.
Link to comment
Share on other sites
The power supply doesn't provide 25A all the time. It provides only as much as the load needs.
If you reduce its output current with a resistor then a load will receive a reduced voltage.
13.8V at 8A is a load resistor of 1.725 ohms. Its power dissipation is 13.8V x 8A= 110.4W.
If you connect two 1.725 ohms resistors in series then each one will have 6.9V and each will dissipate 6.9V x 4A= 27.6W.
Maybe you want to LIMIT its max current to 8A. An electronic circuit might be added to its circuit to do it. Attach its schematic.
Link to comment
Thanks for the reply, I guess my math was wrong. I was using P = V squared / R which would be 13.8 squared (190.44) / 1 = 190.44W. Yes, I want to limit the maximum amperage running through so that it doesn't get all the way up to 25A. Having a way to vary the max amps would be really nice. I'm currently experimenting with Peltier modules and I don't want to fry it by putting too much amperage through it. It's probably just me, but I don't see any link to a schematic that would limit the amps to 8.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
