Jump to content
Electronics-Lab.com Community
SMPS question...
evilrichy
Hi all,
My backgroud is polymer electronics mainly, but I'm looking into designing a power supply to run one of my devices from mains.
My knowledge in this is rather limited - so apologies in advance!
The specs for what I want are;
Mains voltage input,
5-10 V dc output @ 100-300 mA,
Efficient as possible,
Compact as possible.
I've been searching the web for suitable designs, but have had no luck so far. Does anyone know if I can make such a supply? Ideally switch mode (I've been told that helps efficiency) and if posible, can it be done without transformer? I only ask this as the size of it would be an issue.
Any help would be greatly appriciated!
Many thanks,
Rich
Link to comment
Share on other sites
Go to an electronics surplus parts store.
I bought some name-brand SMPS 5V/2A tiny and lightweight power supplies that were made by a computer router manufacturer for $2.50CAN each including taxes. Their voltage regulation is very good and their high frequency ripple is low.
I have some similar very small SMPS that were made for charging cell phones.
Link to comment
Kevin
No!!! A DC-DC converter has a DC primary. You've never heard of a "off-line switcher"? It's still a DC-DC converter on the back end with a AC-DC front end. What do you think the power supply in your computer is??
perhaps one may not call it smps, but Triac (primary comtolled) AC-DCconvertes are not unpopular. may be the type of technology was used for battery charging.
Sarma
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
