installer2001 Posted April 1, 2007 Report Posted April 1, 2007 hello guyswell i am planning to make a security system for an industry.In this i want to include human voice detector.well i have planned that but want the ckt.To start with First of all voice will be converted into electrical signals through MICThen that signal will be matces with our stored signal in the MICROCONTROLLERif both voice matches then the door opens plz plz help me bcoz i know u guys are really genious Quote
ante Posted April 7, 2007 Report Posted April 7, 2007 You will need more than a microcontroller to do this. To make a system like this secure it requires some sophisticated software and storage for all the samples from the people passing in and out of the factory/office building. Quote
bose-einstein Posted May 10, 2007 Report Posted May 10, 2007 Hi,Once,i found a chip on the internet for voice recognition.It was about $100 .I do not quite remember.I will still check if i can get the chip.If not , you will need to write software for the voice recognition.I have some document also on it but its in french.AS i said,i will still look for the chip for you. Quote
bose-einstein Posted May 10, 2007 Report Posted May 10, 2007 Ok,i got the link.Please check these:http://www.sensoryinc.com/html/products/ics.html Quote
Omni Posted May 22, 2007 Report Posted May 22, 2007 Buy an old C64 and load-in SAM... ;DSAM, what a marvel for its time!http://members.tripod.com/the-cbm-files/speak/ Quote
audioguru Posted May 22, 2007 Report Posted May 22, 2007 Use a counter/decoder like a clap on-off circuit.Then when you say O-PEN, the door opens.When you say CLOSE, the door closes.When you bark twice, the door opens.When you bark one time, the door closes. ;D ;D Quote
LostViking Posted June 5, 2007 Report Posted June 5, 2007 There was a small IC I saw years ago that would do exactly what you want. It's all in the chip. You do have to train it, but there is a secure and non-secure mode that uses the recognition threshold. It was something I was going to use to turn lights on and off as part of a home automation system. I did a web search and found something interesting from Phillips called the Hello IC. Give it a look see. Quote
