Jump to content
Electronics-Lab.com Community
Sign in to follow this
ben23
building a generator
how do I use a standard 240v single phase ac motor driven by a petrol engine to create 240vac between the active (hot) and neutral wires of the motor?
if i got a 2400w motor and drove it at the appropriate speed would it push out the full 10 amps that it would normally draw. (maximum capacity of australian powerpoints in the house, except for 15a air con / specialty sockets)
is there any components i need to make it work and is there anything i need to watch out for?
thanks
ben
Share this post
Link to post
Share on other sites
If you take an induction motor and drive it faster than it synchronous speed it becomes a generator or also called a "asynchronous generator" To use this as a generator without any external AC source you need something to supply the reactive power. This can be done by capacitive loading.
Share this post
Link to post
any idea where to get a large capacity induction motor, do dryers have large induction motors?, single phase aircon would have a beefy one, if it wasnt hermetically sealed with the compressor
Share this post
Link to post
:) i would try useing a motor to turn a car ac alternator and with its biult in regulator use it to recharge a car battery then from the battery use a 12 to 240 volts invertor and from that ya have house hold ac power output
Share this post
Link to post
yer that was my first idea but i dont want the added weight of a battery and inverter, rather just have the engine, induction motor (alternator) and capacitor bank and have it wired to a standard power point
Share this post
Link to post
Hi Ben,
A car alternator can be used as a three-phase AC alternator if the diodes are removed. It is also possible to re-wind it to suit the voltage required. If you don
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
