Jump to content
Electronics-Lab.com Community
PIC won't work with capacitors
I have a very simple circuit that oscillates an LED with a program on the 16F628.
I am using a 4Mhz crystal and I find that the program will not run at all when the capacitors connecting each pin of the oscillator to ground are connected, but runs when they are connected.I am using 22pf capacitors, I have tried 10pf and 45pf. The oscillator is a crystal oscillator and it recommends 18-35pf in the datasheet. Any ideas?
I need to stabilise the oscillator as it will be used for data output. It's a PIC16f628
Link to comment
Share on other sites
What you are saying does not make any sense.
Link to comment
hi,
Look at  page 93 of the 16F62X datasheet.
Are you using a series or parallel cut crystal?  also note the possible requirement for a series resistor in one leg of the crystal.
Have you correctly configured the PIC using the _CONFIG, to suit your crystal?
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
