Jump to content
Electronics-Lab.com Community
Posted
hi,
My sincere thanks for providing me the datasheet of LA2000. But, i very much need the datasheet of M51161P, which is obsolete and discontinued IC. So, IC parameters required for replacement etc. Can u pls tell me if M51162P is identical and can be directly replaced?
Thanks you once again. I am also joining unto your website......hope to explore further , i remain.
truly yours,
Shamim
Posted
hi,
Can anyone help me out whether M51161P & M51162P 20-Pin DIP are pin compatible and identical? I am finding it very very difficult to get datasheet for M51161P, but however, I am being able to trace out datasheet for M51162P. Are they identical and can be direcctly replaced or modification in circuitry needed.
Regards,
Shamim-India.
Posted
Search Results 2 more hours.
M51161P Mitsubishi
M51161P-MIT        RECORDER ALC
M51162P-MIT        DUAL MIC/EQ/LINE AMP
http://www.icxinyi.com/EN/zlsearch.php
They want money for it but they have it.
CASSETTE DECK RADIO DIAGRAM\SANSUI\SERVICE MANUALS
for the following Sansui Models have this IC in them.
D-M55F  DM55F
D-55M  D55M
D-65BW  D65BW
D-65CR  D65CR
D-75BW  D75BW
D-77F  D77F
D-M77R  DM77R
D-M77W  DM77W
D-95WR  D95WR
D-99D  D99D
SANSUI SERVICE MANUALS DM55F D55M D65BW D75BW D77F DM77R DM77W D95WR D99D
H:\DATASHEET\MITSUBISHI DATASHEET\M51161p\01.PNG
H:\DATASHEET\MITSUBISHI DATASHEET\M51161p\02.PNG
H:\DATASHEET\MITSUBISHI DATASHEET\M51161p\03.PNG
I am looking for the service manuals now to get the schematic out of them.
What is yours out of?
Make and Model?
I may be able to find a service manual for it.
Posted
Thanks for the information. My Radio/Cassette recorder is now in dead condition. I very much need the datasheet for M51161P, which may be the MIC/Equalisation/Line in/ALC  etc.
This is used in RISING Radio Cassette Recorder (Single Deck) Metal set of Japan Make, Model #  PC 007.
The PCB mounted (with M51161P & LA2000) unto the Deck mechanism clearly mentioning  the connection of the stereo head. So, I need to know the circuit diagram/data sheet for the same.
Regards,
Shamim
Posted
Sir(s),
I wholeheartedly thank you very much for the pains taken guiding me on the above. But, still I have not reached the goal.
The Rising Radio Cassette Recorder (Made in Japan) have the ICs LA2000 (Plunger drive), M51161P for ALC & Pre-amplifier/Mic/Rec. Amp., LA4461 & LA4460 for Power Amplifier) with Detatchable speaker system.
Regards.
Shamim
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
