wyverngod Posted April 23, 2007 Report Posted April 23, 2007 Hello, forgive me for I am just starting to get into electronics but a friend of mine has come to me to help him with a project. He's asked me to come up with a way to control a keyboard via a computer. So far I've took apart a keyboard and have tried to learn what I can about the protocols used by the ps2 ports it used to communicate to a computer and have come to the decision that instead of recreating a keyboard signaling ability that I would take the board from a keyboard and "simulate" the pressing of key by bridging the connections you would normally bridge by pressing a button. But this idea is about as far as I could go. I'm thinking that I would need some sort of USB interface to a micro controller that I would send a code to, that code would be used to "decide' what two pins to bridge. beyond that I'm at a stopping point. does anyone here have an idea where I need to go from here? What kits I should get and so forth. I am a programmer but electronics, and micro controllers are a new thing to me so any help would be useful. Thanks. If it helps any the bridged connections I would have to make are the number of possibilities between a group of 10 pins and a group of 21 pins so about 210 possibilities. Quote
gramo Posted April 24, 2007 Report Posted April 24, 2007 Having 31 spare Pins is a big call for most micro controllers, I did make something similar that can be found herehttp://users.tpg.com.au/gramo/Site/computer_keyboard.htmMight give you some ideas? Quote
wyverngod Posted April 24, 2007 Author Report Posted April 24, 2007 being new to this i'm going to assume that the bc550 listed on your diagram is like a "switch" and that when you send a signal to it it causes the bridged conection that simulates what would happen if you press a key on your keyboard? That leads me to think i would almost need 1 pin/bc550 for each "key" that needs to be pressed. also i found another keyboard that has a 15 group and a 9 group for 135 posable conections.. atleast that shortens it to 24 pins total Quote
