Jump to content
Electronics-Lab.com Community
Problems on transformer equivalent circuit analysis.
alexander3133
Tests are performed on a 50Hz transformer which yield the following results:
Short circuit test: primary voltage = 40V, primary current = 10A, Power input = 20W
Open circuit test: primary = 240V, primary current = 1.2A, Power input = 70W
Determine the equivalent circuit parameters, the turns ratio and the regulation of the transformer assuming that the rated primary voltage is 240V @ 50Hz and the rated secondary current referred to the primary is 10A.
The equivalent circuit parameters is not a problem to me, the only problems was to find the turns ratio and the regulation. I was told that the turns ratio can be found in open circuit test, but how?and also the regulation.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
