blueroomelectronics Posted May 2, 2007 Report Share Posted May 2, 2007 Well as usual audioguru got me thinking about driving transistors to saturation. I've been using MOSFETs (sometimes incorrectly) and I have a problem that may or may not have a simple solution. I wanted to use a 2N7000 but it's only rated for 200ma continuous. I'd like to switch as close to the full 5V as possible for use with a GLCD display. I will see how bright a 2N4401 with its 0.7v drop will run both a 128x64LCD or a standard 2x16 LCD backlight.PS the PTC is getting uprated to 250ma (they open at twice their rating)PPS the Unicorn can be USB powered or Inchworm+ powered (up to 1A)http://www.blueroomelectronics.com/Unicorn.htm Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 3, 2007 Report Share Posted May 3, 2007 Hi Blueroom,I made some LED "flashlights" (they flash 5 times in half a second then pause to cool for half a second. The LED is blasted with 90mA for 30ms so it is very bright and its 9V battery lasts a long time).I tried 2N7000 Mosfets and 2N4401 transistors and they both performed the same.The 2N4401 has a typical saturation voltage of only 0.18V at 250mA with a base current of 20mA. A weak one is like a weak 2N7000 Mosfet that costs much more. Quote Link to comment Share on other sites More sharing options...
blueroomelectronics Posted May 3, 2007 Author Report Share Posted May 3, 2007 I'll have to add 2N4401 to the junkdrawer. I've got plenty of 2N2222A. Can I use a 680 resistor to drive it. Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 3, 2007 Report Share Posted May 3, 2007 Hi Blueroom,A PIC has a max output current of 25mA so a base resistor value of (5V - 0.9V)/25mA= 164 ohms will allow the transistor to saturate the best. Use 180 ohms.I used 680 ohms for the Mood Light because its current per LED never gets anywhere near 350mA. Quote Link to comment Share on other sites More sharing options...
