Jump to content
Electronics-Lab.com Community
hi,
I would not normally fit a fusible resistor in a battery charger, a standard, slow blow fuse would be OK.
If its a typical battery charger I would expect a 5 or 10Amp fuse would be OK.
Does the battery charger have a current meter??
>> relation between the  peak primary current?
I'm not sure what you are comparing with peak primary current????
Link to post
Share on other sites
output power is 1.25W. we used 10E,1w fusible resistor. it got blowed & diode in the bridge rectifier connected in the neutral path also got blowed.then we used 20E,1W fusible resistor, again same thing happened. can u assist me what to do further? ther e is no current meter. my question was is there any relation b/w primary peak current to choose the value of fusible resistor or fuse. if not how to calculate fuse value.
Link to post
If its blowing the bridge rectifier, the problems not with the fuse link.    I would suspect you have a short on the output of the charger. Have you tested across the output terminals with a ohms meter. [ WITH THE MAINS POWER DISCONNECTED] ???
Also, does it blow fuses when no battery is connected to the output??
Also, is the charger rated at the same voltage as the battery, example:  12Vcharger, 12Vbattery??
Also, is the input mains selection for the transformer set for you local mains supply voltage???
Link to post
The 2 boards that are blowing fuses, have you done a resistance check on the output pins.
I sounds as though you have short on the boards, especially as they blow with no battery connected.
Do you have a circuit you can post, it will make it easier to suggest a repair.
Are the 3.6 Vbty  for mobile phones?
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
