Jump to content
Electronics-Lab.com Community
Re: 0-12 Volts LM317 PSU
If the output is 1V at 1.5A and the input is 18V then the power in the LM317 is (18V - 1V) x 1.5A= 25.5W.
The thermal resistance of the TO-220 case is 4 degrees per Watt and if the ambient temperature is 30 degrees C then the chip will be at (4 degrees x 25.5W) + 30 degrees= 132 degrees C. But its max allowed temperature is 125 degrees C.
Adding an electrical insulator will make the temperature of the chip higher.
A heatsink is not perfect (it also heats up) so the temperature of the chip will also be higher.
Link to comment
Share on other sites
Sorry
 I don't know were the 18 volts came from the original post shows a 12 volt input. I figured he would use a 12 volt transformer  to start with and then use the regulator to lower it. And that would of been (12 - 1) x 1.5 = 16.5W
( 4 degrees x 16.5) + 30 degrees = 96, well under the max allowed temperature. Ya but still hot.
                    gogo
Link to comment
An LM317 with a 12V output needs an input of at least 15V.
I was mistaken when i thought the output should be 15V then the minimum input must be 18V.
A 12V transformwer has a peak voltage of 17V which is reduced to about 15VDC by the rectifiers and filter capacitor.
If the output is set to 1V then the LM317 will have 14V across it and will try to dissipate 21W.
You must include the thermal resistance of the heatsink and electrical insulator into your temperature calculation.
Link to comment
Thanks Guys
    I'm not real good at building power supplies, mine are pretty simple. When I need a good large one I would use a prebuilt by someone who has the right stuff to do it with.
    I think this fall I am actually going to break down and invest in a oscilloscope and study power supplies along with a lot of stuff.  The reason is because I am getting ready to retire and am going to need something to keep me busy, so why not a hobby I enjoy.
  When I see something I don't understand I tend to ask questions and I might be a little crude about it. Sorry about that.
    Yes Hero999 if you don't mind please your schematic for the center tap power supply.
                                    thanks again
                                        gogo
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
