Jump to content
Electronics-Lab.com Community
Overload Protector A16 ???
tjolle62
In a few circuit diagrams i have they refer to a what seems to me is a transistor
with B C E as a overload protector and with number A16 and i have looked for a few hours on the net and i can't find anything on this little fellow,
Anyone knows what I'm looking for and wanna share that info Please ....
Come on !! 48 visits !! some one must know what it is !!! PNP is it also...........
Link to comment
Share on other sites
It could be used as a switch, amplifier or (as you've said) part of a current limiting circuit.
Bipolar transistors have so many applications that it's impossible to tell you what it's doing from what you've said. For example if I asked you "I've seen a flat head screw; what's it holding together?", how could you know the answer?
If you post a picture I might be able to tell you but even then the only way is to post a schematic.
Link to comment
Yes, it's being used as a current limiter.
The 2N2955 is a booster transistor, when the voltage across the 50R resistor (or is it 60R? the schematic is too fuzzy) exceeds about 0.7V it turns on, allowing current to bypass  the regulator.
A16 is acting as a current limiter, when the across the 0.1R resistor exceeds 0.7V it turns on which pulls the base of the 2N2955 closer to the emitter, causing it to turn off.
What output voltage do you want to get out of this?
With a 9V transformer, the maximum output voltage is 5V.
How much current do you want to draw?
The transformer is rated to 2A but with the values shown, the current limit will be about 7A.
Link to comment
Now we getting somewhere !!
In my mind i had a theory that if i wanna use for example a car battery as feed and
it would be great if i could draw 5V - 3-5A out of this circuit.
I'm sure that it is better solutions for this task out there but i got curious about
that A16 thing !!!
Link to comment
Yes, you'll nevery get any help until you give enough information.
that A16 thing !!!
Yes, it will work although it's a very crude and inefficient solution, a switching regulator is better idea.
Link to comment
Sorry if my question was little fuzzy before but after 12 years my english has become a bit rusty !!
like i wrote previous so was i more curious in this A16 - 1A16 model of pnp trans,
just putting together a piggy back TIP2955 on a LM317 and it works great,
Thank you Hero,
//Kjell /Sweden.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
