MOSFETS in parallel
The 2N2222 is there to turn the MOSFET off. The 2N3055 gain is low. The 330 ohm will "slow down" the MOSFET turn-on. Why 4 MOSFETS in parallel? The IRF510 is a 100V 5.6A device with an Rds on of .54 ohms.
You will need a snubber across the primary winding or MOSFET (maybe both). You show a 3A source... what do you think 4 MOSFET's will do for you besides lower "Rds on"? Better devices are out there.
I don't see what the 2N2222A is adding to the circuit, if anything it's making it worse not better, I'd get rid of it and drive the MOSFET directly from the 555.
MOSFETs can be paralleled but why not use a single better MOSFET such as the IRL540, rather than loads the obsolete IRF510.
The 2N2222 can sink a lot more current than the 555, so the "turn off" will be faster... and thats a good thing.
Unfortunately, the turn on will be slower due to the 330R.
I doubt there's a significant difference between driving it directly from the 555 and via the 2N2222A.
With the values shown, it could switch at up to ~48KHz... your not going to drive that MOSFET with a 555 directly at that frequency.  A 555 can only sink ~200mA whereas the 2N2222 is good for 1A.
Yes, exactly what I said in my original reply.
Why not? The 555 can work all the way up to 500kHz.
0.8A.
Would using a push-pull emitter follower configuration be any better?
YES!!!
Put the gate resistor in the collector of the NPN not to "over-drive" the MOSFET and the PNP will be able to turn it off faster.
Most of our designs have PWM's capable of 1 or 2 amp's and if they don't, a driver is used.
That transistor has absolutely nothing to do with the biasing of the MOSFET!!! If you take it out of the circuit, the MOSFET is still "biased" on. It's sole purpose is to turn the MOSFET off. You could run the MOSFET directly from the 555... the problem is that the 555 doesn't have the current driving capability to switch it fast. Anytime you have a MOSFET switching a high current load, you have to switch it fast to minimize "switching losses"... that's the I
