Jump to content
Electronics-Lab.com Community
What the value of Zout???
walid
Hello guys
The attached photo is a crystal oscillator
it is a voltage divider config. but replacing the RC with LC tuning tank
I need to know the out put impedance Zout??
Is it XC// XL at the operation freq 27MHz???
please help me
thank you in advance
http://NOTE: sorry L= 3.48 uH not 1.2 uH as in the circuit
Link to comment
Share on other sites
Yes, the output impedance will be equal to the impedance of the inductor and capacitor in parallel.
The impedance of an ideal inductor and capacitor in parallel is infinite, in reality is won't be infinite but it'll be very high and depend on the Q of the tank. Any load connected to the output will reduce the amplitude and stability of the oscillator because it will affect the Q of the resonant circuit.
Link to comment
What the solution then??
Do I have to replace the coil with a stepdown RF transfrmer??
What is the turn ratio then if i want to match with 100K ohm load?
thank you in advance.
Link to comment
Hi Guru
Thank you for attention
What do you think of this circuit
from: http://www.talkingelectronics.com/projects/27MHz%20Transmitters/27MHzLinks-1.html
The author use a transformer then PI network filter for impedance matching the low Z antenna (50 ohm) to the very high (near infinity) Z tank circuit.
I am a week ago, trying to understand, and I hope that you help me to understand
Link to comment
Hello guys
In the following link,
http://www.electronics-tutorials.com/amplifiers/negative-feedback.htm
the author speaks about how to made the necessary calculations to determine the transformer's turns ratio and also the LC needed for impedance matching a 50-ohm antenna to the preceding stage
Regardless of some of the details that the writer is talking about, espicially his talking about the dc biasing and the o/p voltage swing, I will focus in the discussion with you on the method of calculating the turns ratio.
Look at the fig:
the author said:
Here we are only mainly concerned here with the principle of a tuned circuit as a load. In this example we have a final load of 50 ohms connected to the output link coupling of our tuned circuit. Assume, just for discussion purposes, that in this example we needed a power output of 100 milliwatt from the amplifier and that we have available a power supply of 12V. Further,
Now:
2 * Po = [Vcc - Ve]^2 / R
or [2* 0.1] = [12 - 3.22]^2 / R
or [2* 0.1] = [ 8.78 ]^2 / R
and R = 77 / 0.2
= 385 ohms
Therefore the load presented to the output of our amplifier needs to be 385 ohms. The impedance ratio is 385 / 50 or 7.7:1 and the turns ratio on the transformer (inductor) is the square root of that number or 2.775:1.
My questions are:
1)Are these calculations are true in general?
2) Why '2' in 2.Po = [Vcc-Ve]^2/R, i learn that P = V^2/R
3)Why [Vcc-Ve]^2, I think it must be [Vcc-Vc]^2
Eagerly awaiting your reply
Link to comment
  • 2 weeks later...
My questions are:
I discover the answer of the second question: the RMS value of the peak voltage = Vpeak/squre root of 2
and when we squre that root we get 2 which appear in the equation.
i need answer to question 3
thank you very much
Link to comment
Hi walid,
I have not done RF work in my career and I haven't done school-work for about 42 years.
The transistor is a linear amplifier so its collector swings down to about 4.5V and swings up to the same amount above the supply voltage because of the tuned circuit. So the voltage swing is doubled.
Read further in the article where the author explains that the transistor is clipping and that its current should be higher. Then re-calculate the impedance of the transformer's primary.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
