Jump to content
Electronics-Lab.com Community
power led drivers circuits?
mir_as82
can i ask you a questions?
how can be produced small size power supply? i need small size power led driver circuit as DX-04350V and DX-MU38-5 like these models in link which is given below.
http://www.diox.com.tr/led_suruculeri_01.asp
if anyone helps me so i will be so glad.
Anyone has circuit diagrams for like these product?
Thanks for your kindness
Link to comment
Share on other sites
But power leds' dinamical resistance are changes by time. if they work much time so their resistance rise. your suggesment s nice but wall wrick power supplies have constant voltage. They have not current feedback. i need constant current feed back power supply.Can you suggest me like this circuits' shamatics? it must be small size. can you look this link?i need a circuit which has AC input.
http://www.em.avnet.com/ctf_shared/sta/df2df2usa/LightSpeed-319-0006.pdf
Link to comment
I know, I wasn't suggesting you should should use a wall wart on its own, that would be a silly idea. The idea was to use a wall wart in conjunction with the Buck puck driver I suggested previously.
The driver you've suggested looks perfect for powering an LED off the mains, no need for a wall wart.
Link to comment
yes hero is right. may be i m lazy so i want to have totally finished circuit:). can i ask you that do professional driver producers use transformers in driver circuits?
forexample is there any transformers in that product.
how can i find like these products inside?i mean circuit shematic diagram.
Link to comment
Then buy a driver and bingo, you have a totally finished circuit.
Yes, the datasheet says it's isolated so there will be a transformer.
However, it's an SMPS so it'll have a small ferrite cored high frequency transformer, not a laminated iron 50/60H power line frequency transformer.
Buy it, open it up, look at the ICs used, get the datasheets and reverse engineer the PCB.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
