xristost Posted February 24, 2012 Report Share Posted February 24, 2012 I know. I do not really need more than 20 volts, so I think a 24 volt charger fits my needs, could use this design with the charger I mentioned earlier?Part of the circuit will not work, because it use AC voltage to make negative supply voltage for U3. But charger will provide only DC voltage. Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 24, 2012 Report Share Posted February 24, 2012 Part of the circuit will not work, because it use AC voltage to make negative supply voltage for U3. But charger will provide only DC voltage.That is only one of hundreds of parts where the voltage is too low. What about the other hundreds of parts where the voltage is too low? Quote Link to comment Share on other sites More sharing options...
du.facc Posted March 5, 2012 Report Share Posted March 5, 2012 Can I add two potentiometers to the "fine tuning"? From what I know, just add the potentiometer in series with the potentiometer in the circuit that already exists, but do not know if this circuit is possible to contain the RV2 and RV3. If possible, which would then potentiometers? Quote Link to comment Share on other sites More sharing options...
audioguru Posted March 5, 2012 Report Share Posted March 5, 2012 A coarse pot and a fine pot would be a nuisance. The fine would almost always be in the wrong position.Use a bigger knob instead on one pot. Quote Link to comment Share on other sites More sharing options...
bugmenot Posted March 14, 2012 Report Share Posted March 14, 2012 Or a multiturn pot. Quote Link to comment Share on other sites More sharing options...
xristost Posted March 14, 2012 Report Share Posted March 14, 2012 I finished my version of this famous project :)Here how it looks like: http://diyfan.blogspot.com/2012/02/adjustable-lab-power-supply.htmlYou may also download PDF files of the project on that page. Quote Link to comment Share on other sites More sharing options...
Guest mikehZA Posted March 17, 2012 Report Share Posted March 17, 2012 Hi,Couple of questions regarding the negative supply:Why is it requiredWhy only used on U3Isn't there a lot of ripple on it? Quote Link to comment Share on other sites More sharing options...
audioguru Posted March 17, 2012 Report Share Posted March 17, 2012 Hi,Couple of questions regarding the negative supply:Why is it requiredWhy only used on U3Isn't there a lot of ripple on it?U1 has an output of +11.2V and its inputs are at +5.6V so it does not need a negative supply.U2 has an output that goes as low as +1.0V and has inputs that work at 0V so it does not need a negative supply.U3 is the current regulator. It works by reducing the output voltage so that the output current is what is set on the current-setting pot. In order to reduce the output current when the output is shorted then the output voltage of U3 must go to -0.7V because of the voltage drop across D9.Then the output voltage can be reduced to 0V.So U3 has a -1.3V negative supply.I don't think the negative supply has much ripple because its load current is only a couple of mA. Besides, U3 is not affected by a little ripple. Quote Link to comment Share on other sites More sharing options...
Guest mikehZA Posted March 19, 2012 Report Share Posted March 19, 2012 Thanks, Audioguru appreciate your clear answer. Quote Link to comment Share on other sites More sharing options...
thenr. Posted April 14, 2012 Report Share Posted April 14, 2012 I finished my version of this famous project :)Here how it looks like: http://diyfan.blogspot.com/2012/02/adjustable-lab-power-supply.htmlYou may also download PDF files of the project on that page.Hi,i will use a power supply 24Vdc 3A instead of a Transformer. Can i eliminate the rectifier diodes, R2 e C2 ?I didn't find MC34071, only MC34072. Can i change ?? Quote Link to comment Share on other sites More sharing options...
lighty Posted April 14, 2012 Report Share Posted April 14, 2012 Hi,I didn't find MC34071, only MC34072. Can i change ??The MC24072 is a dual opamp configuration, it should work but its not a direct replacement part, as the pinout is different, but if you can work around this, then I'm sure you could. PS, you will loose the offset too. but not a train smash though.Thats just my opinion, perhaps wait for some pro's to answer. Quote Link to comment Share on other sites More sharing options...
audioguru Posted April 14, 2012 Report Share Posted April 14, 2012 Thenr,This project uses a 28VAC or 30VAC transformer. The rectified and filtered unregulated DC is +37.6V to +40.4V when the load is 3A, not just 24VDC. The circuit might need changes to operate from only +24V and the max output voltage will be about +18V or +19V.Go to www.farnell.com and click on the flag of your country. They might have a warehouse full of MC34071 or TLE2141 opamps in your country. Quote Link to comment Share on other sites More sharing options...
Tompa Posted April 22, 2012 Report Share Posted April 22, 2012 HelloI build modified version of this PSU... and i got 1 problem.... PSU worked fine untill today (when I put it inside the case/box)... something went wrong.. I cant regulate output voltage.. I got constant 36V.....U2 is getting very hot after few minutes.... This is PSU when it worked... now is broken :/sry for my bad english... Quote Link to comment Share on other sites More sharing options...
mendimano Posted April 22, 2012 Report Share Posted April 22, 2012 Well Tompa it is dificult to help you from here, maby you should check your output tranzistor/tranzistors,i watched the video and your P.S worked then just fine, check for any wires soldering joints wich might broaken during the instalation of your P.S to enclosure. Quote Link to comment Share on other sites More sharing options...
redwire Posted April 23, 2012 Author Report Share Posted April 23, 2012 Tompa, How many and what type (T0-3 or T220 package) of output transistors are you using. The heat sink looks a bit small. Without being able to see the amps clearly, I am assuming you are pushing 4 amps and the output transistors are having to burn off over 80W. Quote Link to comment Share on other sites More sharing options...
denci Posted May 6, 2012 Report Share Posted May 6, 2012 So, this is my first post on this forum, first hi everybody!! ;DI will make this project in near future therfore i am interested how to calculate total dissipation on transistor 2n3055.I will use the 5A (REV3) version of this project, so i'll use three transistor and transformer 30VAC 210VA.I need this calculation for calculate heatsink thermal resistance for three paralleled 2n3055.Is this calculation is correct or not:Pd = 5A * (40V - 0,55V - 1.35V) = 190,5Wi got 0,55 from total voltage drop of three 0,33ohm paralled resistor (0,11*5), 1.35 is voltage drop on shunt resistence R7 (0,27ohm*5A) Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 6, 2012 Report Share Posted May 6, 2012 .....calculate total dissipation on transistor 2n3055.I will use the 5A (REV3) version of this project, so i'll use three transistor and transformer 30VAC 210VA.I need this calculation for calculate heatsink thermal resistance for three paralleled 2n3055.Is this calculation is correct or not:Pd = 5A * (40V - 0,55V - 1.35V) = 190,5Wi got 0,55 from total voltage drop of three 0,33ohm paralled resistor (0,11*5), 1.35 is voltage drop on shunt resistence R7 (0,27ohm*5A)Your calculations are correct. When the output is set to 5a and is shorted then each 2N3055 output transistor must dissipate (190.5W)/3= 63.5W.A huge heatsink cannot provide enough cooling so a high velocity fan must be added. Quote Link to comment Share on other sites More sharing options...
denci Posted May 6, 2012 Report Share Posted May 6, 2012 I calculated the heatsink wit aprox. 0.5°C/W thermal resistance for one transistor, how much must be that for three 2n3055.What fun you suggest?? what dimension and voltage? Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 6, 2012 Report Share Posted May 6, 2012 If you don't use insulators for the transistors when you can insulate the heatsnk from the chassis and prevent somebody from shorting it to ground or getting a 40V shock.Thermal compound adds about 0.2 degrees C per Watt so the cooler is 0.7 degrees C per Watt.Maybe the ambient temperature is 30 degrees C. Then 190.5W causes the chip of each transistor to become (190.5 x 0.7) + 30= 163.4 degrees C which is extremely hot but not too hot (200 degrees C is the maximum for a 2N3055).I buy heatsinks where the manufacturer lists dimentions and thermal resistance. If you make your own then you are just guessing. Quote Link to comment Share on other sites More sharing options...
LEECH666 Posted May 12, 2012 Report Share Posted May 12, 2012 Hello once again. I still haven't managed to build this supply even though I designed my own PCB, which probably is still crap. Who cares.The reason I post here today is because I finally want to finish the PSU and I am not sure what type of heat sink I should pick for Q2 (BD139). It only says "on a pretty big heat sink" in the parts list, which is a kind of vague assertion.Some toughts on this topic (not necessarily correct or complete):Q2 is used to drive the two power transistors Q4 and Q5. At the nominal 3A output current (IOUT=3A) the current gets shared between the two transistors and each transistor has to handle 1.5A of current. I took a look at the OnSemi datasheet for the 2N3055 and the minimum DC current gain (B) seems to be 20 (worst case).IB = IC / BIB = 1.5A / 20 = 75 mASince we're driving two 2N3055s we have to supply two times the base current that I just calucated.IBx = 2 x IB = 2 x 75mA = 150 mASince I sort of suck at electronics I have no idea how much voltage the transistor Q2 will see (worst case). However I need the voltage to calculate the total power dissipated by Q2, which then would allow me to calculate an appropriate heat sink.Looking into the output transitor circuit more closely I think it kinda works like this:Supply Voltage:US = 30VQ2 Emitter Resitor Voltage:UR16 = UR24 + UBE_Q5 = (IOUT/2 * R24) + UBE_Q5 = (1.5A * 0.33R) + 0.7V = 0.495V + 0.7V = 1.195VQ4 and Q5 Collector Emitter Voltage:UCE_Q4 = UCE_Q5 = US - UR24 = 30V - 0.495V = 29.505VQ2 Collector Emitter Voltage:UCE_Q2 = US - UR16 = 30V - 1.195V = 28.805VPower dissipated in Q2:P_Q2 = UCE_Q2 * IBx = 28.805V * 150mA = 4.32WThermal resistance of (heat) sink to ambient:RthSA = to be calculatedThermal resistance of case to (heat) sink (thermal grease layer):RthCS = 0.3K/W (don't know where this number comes from, http://sound.westhost.com/heatsinks.htm#s7 suggest 0.25 for beryllium oxide which is kind of grease like (?))Thermal resistance of transistor junction to case:RthJC = 10K/W (from ST datasheet)Maximum ambient temperature:Ta = 55°C (selected, ambient temp in summer in north germany hardly ever gets over 35°C, 20°C safety margin included)Maximum operating junction temperature of transistor:Tj = 150°C (from ST Datasheet)Tj = P_Q2 (RthJC + RthCS + RthSA) + Ta(equation from http://irf.custhelp.com/app/answers/detail/a_id/91/~/heat-sink-selection-and-thermal-calculation.)Solve for RthSA:(Tj-Ta/P_Q2) - (RthJC + RthCS) = RthSARthSA = ([150°C - 55°C] / 4.32W) - (10K/W + 0.3K/W) = 11.69K/WRthHS = RthSA * 0.80 = 11.69K/W * 0.80 = 9K/W (another 20% safety margin)So the heat sink should have a thermal resistance of around 9K/W or lower.Hope my calculations are ok, not entirely sure. I probably forgot to take the rectification factor into account and US is probably higher than 30V.What type of heat sink did you guys use in your build of this PSU?Florian//Edit: Few typos corrected. Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 12, 2012 Report Share Posted May 12, 2012 With a 28VAC transformer the unregulated positive supply is +37.6VDC. When the output is shorted then the BD139 has a max current of 50mA and a voltage of about 36V so it dissipates 1.8W. It is in an old package so its ability to cool itself with a heatsink is poor. Quote Link to comment Share on other sites More sharing options...
LEECH666 Posted May 12, 2012 Report Share Posted May 12, 2012 Ah thanks. I'll have to adjust my calculations then.I've got a 160 VA transformer with 1x 230V primary and 2x 15V (5,33A) secondary windings.Im going to put the secondary windings in series so the resulting RMS voltage should be 30V.My rectifier bridge drops 1.1V for each diode inside of it. So I guess my total unregulated supply voltage should be:Us = 30V * sqrt(2) - 2 * 1.1V = 42.43V - 2.2V = 40.23VIf the TO-126 package of the BD139 is so bad couldn't I just use some other general purpose NPN transistor in a TO-220 package? Or maybe drive some Darlingtons directly from the opamp instead of the 2N3055?Florian Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 13, 2012 Report Share Posted May 13, 2012 The very old 2N2219 driver transistor in the original circuit had a good high frequency response so its transient response was good. I suggested replacing it with a TIP31 transistor that can be cooled well but another member showed that its slow response almost causes oscillations and rercommended the very fast BD139.A darlington will be much too slow. Quote Link to comment Share on other sites More sharing options...
LEECH666 Posted May 13, 2012 Report Share Posted May 13, 2012 I noticed that only the original Philips datasheet of the BD139 specifies a value for fT = 190 Mhz. So far I haven't found a transistor in the TO-220 package that's that fast. I think the fastest one I've found so far is the 2SD1762 @90Mhz or so, but the dc current gain doesn't seem to be as high. MJF44H11 seems to have a similar minimal dc current gain and fT=50Mhz.*sigh* Not as easy as I thought. ;)Guess I'll just stick to the BD139 for now and see how that transtor works out on a heat sink.Thanks again for your help audioguru.Florian Quote Link to comment Share on other sites More sharing options...
denci Posted May 13, 2012 Report Share Posted May 13, 2012 So, what heatsink do you suggest, how much should be a thermal resistance, i have one heatsink with 5°C/W at home, which I intend to fix on housing of BD139.I think that it is enought for condition in this stabilized power supply with max 5A current or not?? Quote Link to comment Share on other sites More sharing options...
