Jump to content
Electronics-Lab.com Community
0-30V Stabilized Power Supply
redwire
Ok, the POTs are working fine, just that when the current is turned down to 0, the limiting LED turns on, could this be because C7 is an electrolytic type?
With the current-setting pot at minimum, a load of 12mA or more will cause current regulation.
Maybe C7 leaks as much as 12mA or more because it is connected backwards or because it is defective?
Opamp U3 is a TLE2141 with a max input offset voltage that is much too low to cause your problem. Maybe U3 is a counterfeit one or is defective?
Link to comment
Share on other sites
Cool, I'll try replacing it. I did notice when I was fiddling with the setting that the output dropped to about -0.3 V.
I think I will try replace C7 1st then test it again, perhaps the offset is way off?
Link to comment
This is the connections drawing for my version of the power supply and updated schematic, To me it looks quite simple
This is the actual size of the PCB and what the layout looks like.
The next thing is to update the component values on the schematic and create BOM
Hopefully over the weekend I shall get PCB made and assembled
POWER_SUPPLY_V2.pdf
power_supply.pdf
Link to comment
Here is the working version on my PSU, There is just just a couple of minor things I have got to look into and clarify. Yes the connecting wires may look a little on the light side but this is for testing only Has I only took to 3amps and calibrated max current for a few seconds to try.
These are the minor things that I have got to look into.
1. Because I'm using a 30V transformer the voltage is slightly to high feeding the op-amps has the TLE2141 is only rated at 44V I got 48V.
2. With the current pot set to Min the limit LED comes and and this restricts the voltage I have to turn it up slightly(not sure what the voltage is at the center of the pot has it is getting late.)
Aslo I'm not sure if this is normal if the limit LED should light up with the pot to min, I did disconnect C10 has if I remember lighty  had the same trouble but it is still the same
I get full control over the current range min current is about 40ma, I did see that is should only be 12ma, I will have to make sure that I've got all the correct components in place first and I will read through the older posts.
Link to comment
A half-decent 30V/127VA transformer is 31V with no load which produces a positive unregulated supply of 42.6V. Since your unregulated supply is very high at 48V then either your transformer is poor or your mains voltage is too high.
Link to comment
  • 2 weeks later...
For 30V output, the transformer must be at least 28V.
For 3A output, the transformer must be 4.2A.
The power from the transformer is 28V x 4.2A= 188W.
The power from your tiny little transformer is 24V x 0.435A= only 10.4W which is 14 times too small.
Your transformer will power a project that goes to 25VDC at 300mA. If you do not change the value of R7 to prevent it from trying to go to 3A then either the transformer will get extremely hot then burn out or it might catch on fire.
Link to comment
So, I can use any transformer on the project, but it will work at a limited power? All I need to do is change R7 and everything is gonna be OK? What more do I need to change?
I don't know if you are making the original faulty circuit or which improved circuit.
Since your transformer is so small then you can make a simpler low power circuit.
Link to comment
Audiogurus, I'm doing the improved one. I did the original and now I have all the components waiting for something. This is why I want to do the good one. Actually my idea is use a transformer with 2A or around it. So, will it work?
Another question: Can I use a smaller capacitor than that ones with 6.800 uF? They're very expensive and if I use a smaller transformer I think they'll be unnecessary.
Thanks again.
Link to comment
Guest Enforcer83
Mauriciovargas,
You can use a smaller capacitor,  but you will induce a greater ripple voltage into the system.  There is an equation that you can use to determine the ideal value for a capacitor given the desired ripple voltage and system current.  However, this equation eludes me at the moment.  Try doing a search for voltage ripple in google.
I will update when I find the equation.
Link to comment
Thanks audiogoru and Enforcer83.
I already know the ripple problem with a smaller capacitor and a big current. But,what I meant to say, is that I don't need more than 1 A. So, can I use this project (audiogoru's 3A version) with my little transformer (24VAC / 435 mA) and a smaller capacitor, like 3300 uF? What more I need to change in the project?
Link to comment
  • admin featured and pinned this topic
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
