Jump to content
Electronics-Lab.com Community
power supply ircuit Help
I am building charging system for 12v tool batters ( drills, lights, etc. ). I found a 12v a/c adapter and I cut the end off the but bullet connectors that hook up to a wire with a shielded female spade connector. The shade fits the 12v battery. My question is - is there a way to design a circuit that will let me know when its charged, like with a red and green light. Any help or schematic would me greatly appreciated
Link to comment
Share on other sites
It depends on what type of battery you have. To charge batteries you need a constant current source, but the method of charge termination varies from chemistry to chemistry. Lead acid batteries charge with a constant current then need a float voltage top off. NiCads and NiMH need a change in voltage with time charge (or temperature). Lithiums need an extremely accurate charge termination (to 100mV accuracy).
Look at the MAX712/713 datasheet from Maxim for NiMH and NiCads.
Link to comment
Lead-acid-batteries are charged with constant voltage e.g. 13.8V. Their charging current decreases while they approach full charging voltage.
NiCads are charged with constant current.
Link to comment
  • 3 weeks later...
A lead acid battery will charge very slowly if charged to 13.8V.
If it's charged to 14.5V and reduced to 13.8V when the current drops below a certain level, it will charge much quicker.
OK! Partially agreed.  :D
Subtract 0.1V for a final charge voltage of 14.4V to make it safe!  ;)
Beyond 14.4V any lead-acid battery starts gasing (Hoffman's electrolytic gas production facility)  ???  ???
H + O mixed make a beautiful firework if touched off by the spark of a switch.  ;D
HtG
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
