Jump to content
Electronics-Lab.com Community
hi !!!!!!
Guest @m@
hey people !! I have designed a low pass filter in stimulation program , but the point which annoying  me is that my low pass circuit have c= 10uF and r=500 ohms so the Fc becomes 31.83Hz  but my circuit passes  a huge amount of large frequency after this range i.e after 31.83 Hz I further increases my frequency by function generator then at kHz it start showing DC at output why it is like that ?  ??? why its doesn't stop signal  after 31.83 HZ
pllz help me
Link to comment
Share on other sites
The lowpass filter reduces frequencies above its cutoff frequency, it does not eliminate them.
At double the cutoff frequency, the output of your simple first-order filter is -6dB which is half.
At double the cutoff frequency, the output of a second-order lowpass filter is -12dB which is 1/4.
At double the cutoff frequency, the output of a third-order lowpass filter is -18dB which is 1/8th.
At double the cutoff frequency, the output of a fourth-order lowpass filter is -24dB which is 1/16th.
Higher frequencies are reduced more.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
