Jump to content
Electronics-Lab.com Community
Battery low voltage cut-off problem
I am facing a problem in my circuit where I made it for switching of a light when the battery voltage reaches 10.55 volt. The battery is 12 volt 3.4Ah SMF type.
The problem is:
When the battery reaches 10.55 volt (roughly) the battery is disconnected from the load. When the battery is disconnected from the load the battery voltage rises a bit and turns on the relay again. This repeats and repeats.
I don't know if the circuit I made is right. Could somebody help me to fix this ?
Link to post
Share on other sites
Yes, there needs to be some hysteresis to prevent oscillation, just connect a 100k resistor between the op-amp's output and the + input. This will make the turn on voltage higher than the turn off voltage, see the data-sheet linked above for more information.
I wouldn't use the LM324 anyway, the LM339, LM393 or LM311 would be much better because they're specifically designed for use as comparators. If you only need one op-amp/comparator then I'd recommend the LM311 which can drive a small relay without an additional transistor.
Don't get me wrong, it'll be fine with the LM324, it just wouldn't be my first choice.
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
