Jump to content
Electronics-Lab.com Community
Guitar Aplifier
fikic
  • Replies 85
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Just to report, I made an LC filter to reduce oscilating and brum..I connected it in series with C13 and to power amplifier...It works great, but I burned everything ;D I turned Volume potentiometer to full and played for 2 minutes really hard, when suddenly everything shuted. I checked PCB and saw broken connection between Q6 Collector and ground..(it was verry tinny connection)..I repair it and replace C6. When I turned circuit on, it started to smoke..As I assume, Q4, Q5 and Q6 are dead. One of them was dead before (Q4 or Q5), so it started to smoke...I am wondering, if I am using to small cooling rib or not too good contact from collectors to cooling rib. I am waiting for new parts. I will replace every transistor and check them all to prevent puting in a faulty component. I will report and I just wanted to say, that LC filter solve the problem of oscilating in huge rating..I will report
Link to comment
Share on other sites
As Q5 and Q6 carry a considerable current, the PCB traces need to be thick enough to carry the current, otherwise it'll behave like a fuse.
Of course the transistors need to be on a good heat sink.
If the amplifier is driving a 4Ω load, the heatsink should be rated to at least 4
Link to comment
I repaired this trace. I soldered 1mm wire instead of pcb trace on it..I will get new parts tommorow maybe. Or else latest in monday. I will report. But I am also afraid, that when I will play on full volume for too long, something will die..Even heatsink won't help. Oh, and about oscilations. Would it be good idea to connect 520pF capacitors between base and collector of Q5 and Q6?
Link to comment
C13 is the main filter capacitor for the power supply. You never want to connect anything in series with it.
Adding a 47pF capacitor from the collector of Q3 to ground (not to its base because the base is used for negative feedback) will reduce high frequencies which will reduce the possibility of the power amplifier from oscillating at a high frequency (you cannot hear the high frequency). Q3 has the capacitor because it is the only transistor in the power amplifier that has voltage gain. Q5 and Q6 have no voltage gain (they have current gain) so a capacitor at them will do nothing but cause trouble.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
