Jump to content
Electronics-Lab.com Community
Sign in to follow this
Kevin Weddle
resonant filtering
An ordinary power supply is not resonant. It rectifies the 50Hz or 60Hz from the transformer and filters out the low frequency ripple.
A high frequency switching power supply is resonant so it can efficiently stepup the voltage or efficiently stepdown the voltage with an inductor.
Share this post
Link to post
Share on other sites
Traditionally most low to medium power high frequency power supplies (<1kW) are not resonant and use PWM to adjust the amount of power i.e. regulate the output current or voltage.
More modern and higher powered SMPes, typically are resonant. The employ a technique known is zero voltage switching where the transistors are only turned on when the voltage across them is zero. Here's a link with more information.
http://www.powerdesignindia.co.in/STATIC/PDF/200901/PDIOL_2009JAN21_PMNG_TA_01.pdf?SOURCES=DOWNLOAD
Share this post
Link to post
If you're talking about EMC filtering then no, resonant filtering is no beneficial, it's harmful because tuned circuits can be excited leading amplification of certain frequencies.
Resonant filtering is only used for tuning a circuit to a particular frequency, for example in a tuned radio receiver a capacitor is placed in parallel with an inductor to form a tuned circuit.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
