Jump to content
Electronics-Lab.com Community
Looking for temperature sensor with +/- 0.5 degree accuracy at 25 degrees.
StephenL
I am looking for temperature sensor with +/- 0.5 degree accuracy at 25 degrees. The DS18B20 would do the job well, but does not work over the range of 1.8V to 3.6V. Other type such as the DS75LV, and LM94022 are not accurate enough.
Digital output is preferred, but can work with analogue output. The sensor is to be built into a probe with a 2 meter connecting lead.
Thank you for any suggestions.
Link to comment
Share on other sites
A thermistor is a good idea.
The uP I am using is the SiLabs C8051F930. The A/D full scale is 1.68V. This would require an amplifier or else the self heating of the thermistor would be high. Also I would need a precision current source.
This job is quite price sensitive. Just hoping for the equivalent of a DS18B20 that runs at 1.8V.
Link to comment
You don't need a current source: use the power supply as the A/D reference and connect the the thermistor as part of a potential divider. Self heating won't be much of a problem as long as you keep the power dissipation low.
I doubt you'll find an IC, high accuracy, low voltage and low cost are not compatible.
Link to comment
  • 2 weeks later...
  • 2 months later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
