Jump to content
Electronics-Lab.com Community
Which software should I use.
ziizoo
please help me find the right software for this program...
i make a project about speech recognition..
i use HM2007 chip for this project.. my project is to convert a voice to text...
if anyone know about this project, please help me guys... :(
URGENT!!!
Thank You..
PROGRAM:
define osc 20
DEFINE LCD_DREG		PORTD	'LCD data port
DEFINE LCD_DBIT		0	'LCD data starting bit 0 or 4
DEFINE LCD_RSREG	PORTC	'LCD register select port
DEFINE LCD_RSBIT	7	'LCD register select bit
DEFINE LCD_EREG		PORTC	'LCD enable port
DEFINE LCD_EBIT		5	'LCD enable bit
DEFINE LCD_RWREG	PORTC	'LCD read/write port
DEFINE LCD_RWBIT	6	'LCD read/write bit
DEFINE LCD_BITS		8	'LCD bus size 4 or 8
DEFINE LCD_LINES	2	'Number lines on LCD
DEFINE LCD_COMMANDUS	2000	'Command delay time in us
DEFINE LCD_DATAUS	50	'Data delay time in us
TRISD = %00000000	'Set port D as output
TRISC = %00000000	'Set port C as output
TRISB = %11111111	'Set port B as input
low	PORTC.6		'Set the R/W bit to low
pause 1000					'wait until the LCD initializes
SCAN:
LCDOUT	$FE,1					'clear LCD display
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$0 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"plz train the HM"
IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$0 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"one"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$0 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"two"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"left"
IF PORTB.0=$1 AND PORTB.1=$1 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"jump"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"gil"
IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"three"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"stop"
IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$0 AND
PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"text"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$0 AND
PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"point"
IF PORTB.0=$1 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$0 AND
PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"socks"
PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"green"
IF PORTB.0=$1 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"word too long"
PORTB.5=$1 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"word too short"
IF PORTB.0=$1 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$1 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0,	"word no match"
pause 1000			'delay for 1 second before scanning the next word
GOTO SCAN
END
Moderator Edit:
Added code tags.
Removed block capitals from thread title.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
