nuel4real Posted January 16, 2010 Report Posted January 16, 2010 hello, some components read in a multimeter while some don't. Please how do I get to know which component is bad while tracing. Quote
Hero999 Posted January 16, 2010 Report Posted January 16, 2010 Please provide more information. Quote
bigsam Posted June 8, 2010 Report Posted June 8, 2010 can you explain deeply ?, I do not understand what you want to ask Quote
Hero999 Posted June 8, 2010 Report Posted June 8, 2010 I mean your question isn't clear and makes no sense. Quote
Sakshi Verma Posted December 16, 2022 Report Posted December 16, 2022 Using a multimeter to test electronic components can be valuable for diagnosing and troubleshooting circuits. Here is an essential process for reading electronic components using a multimeter: Set the multimeter to the correct measurement range. Different components will require different ranges, so consult the user manual for your multimeter to determine the appropriate setting. Identify the component you want to test. You may need to refer to a circuit diagram or documentation for the device to determine the type of component you are dealing with. Determine the proper way to test the component. Different types of components will require different methods of testing. Quote
