HarryA Posted February 2, 2010 Report Share Posted February 2, 2010 I have a new power supply that I would like to check before installing into the computer. On bench testing it I get novoltage at all. Is thid correct? I am thinking that perhapsthere is some type of interlock so you only get voltagewhen it is installed?thanks in advance. Quote Link to comment Share on other sites More sharing options...
Alex Tsekenis Posted February 2, 2010 Report Share Posted February 2, 2010 Have you switched on the power supply from the motherboard connector? Is it a 24 or 20 pin (the main connector) PSU? Does the fan rotate?http://www.ochardware.com/articles/psuvolt/psuvolt.htmlThere are also cheap PSU testers...http://www.frozencpu.com/resource/r12/Using_a_Power_Supply_Tester.html Quote Link to comment Share on other sites More sharing options...
jcizek Posted February 2, 2010 Report Share Posted February 2, 2010 You must "turn on" the supply within the connector if this is a modern ATX type power supply. Usually (take that at face value, lots of power supplys are differernt) it's the skinny blue wire in the motherboard harness that must be grounded to turn the supply on. You will also need to load the 5 Volt line (red wires on the output) with a load for it to regulate properly. Alex is right, a power supply tester is the safest way to test them, and keep from blowing up a brand new supply! -James Quote Link to comment Share on other sites More sharing options...
HarryA Posted February 4, 2010 Author Report Share Posted February 4, 2010 Thanks guys. That's what I needed to know :)I made a tester out off a 12 v brake light anda 6 volt one ;) Quote Link to comment Share on other sites More sharing options...
