Riccardo Posted March 29, 2010 Report Share Posted March 29, 2010 Hi,I just want to check if I am understanding the SOA graphs correctly on a datasheet..The STP30NF10 MOSFET is rated for 100V and 35A.http://www.datasheetcatalog.org/datasheet/stmicroelectronics/7817.pdfThe SOA graph shows that the actual current it can pass varies with Vds. Now the graph goes upto 100V, but Vds (when on) should be really small, so is this referring to the Vds voltage when off?Looking at the graph, and taking a 24V supply as an example, it looks like it could only switch something less than 5A. Is this correct? Is this still true even when on a large heat sink?It also shows the current handling peaking at around 3.5V. I don't really understand why lower voltages lower the current ability. Its also seems odd that a transistor rated for 100V, 35A should only work at 35A when switching from a 3.5V supply.Where am I going wrong? Quote Link to comment Share on other sites More sharing options...
Hero999 Posted March 29, 2010 Report Share Posted March 29, 2010 No,The graph show how much current the MOSFET can pass when it is not quite fully switched on. If it was switched off then no current would be flowing.The graph has nothing to do with switching and is about the saturation region when the MOSFET is neither fully on nor fully off and is dissipating the most power.When the MOSFET is off the VDS is high but the current is near zero.When the MOSFET is fully on, the current is high but the VDS is near zero.There will be a fraction of a second when the MOSFET is in the process of turning off or on, when both the VDS and current will be high but it doesn't matter as long as it's switching fast enough for the power dissipation to be negligible. Quote Link to comment Share on other sites More sharing options...
Riccardo Posted March 29, 2010 Author Report Share Posted March 29, 2010 Oh good! I couldn't understand how the physics of what I thought I was reading could work! Thanks for clearing that up ;D Quote Link to comment Share on other sites More sharing options...
