Jump to content
Electronics-Lab.com Community
White led
It depends on whether it can withstand a short circuit or not.
Please post a schematic.
An easy way is to connect a 100R power resistor and measure the voltage, it should be 35V.
You might be able to get away with a 10R resistor or even just measuring the current with a meter but it depends on the power supply.
Link to comment
Share on other sites
The resistor needs to be rated for at least 5W and don't leave it connected for very long - the power dissipation will be 0.352*100 = 12.25W which is much higher than the maximum rating but will be fine, as long as it's only connected for a few seconds and a large heatsink is used.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
