kennyp Posted March 30, 2010 Report Share Posted March 30, 2010 HALLOI want to ask the inverter circuit can increase/decrease Something to change to converter circuit??also,I'm looking for a 12vdc to 220vdc of the converter. I can not find on the network , I hope you can help to me.In addition, you have heard out of the water solution of hh and o, then use the hh and o be used as fuel for cars? If you know, then what should the voltage be OK??Thank you for your answer Quote Link to comment Share on other sites More sharing options...
audioguru Posted March 30, 2010 Report Share Posted March 30, 2010 HHO for cars is a SCAM. Nobody has ever proved that it increases the fuel economy.It takes more power to break water into HHO than you get from it so you actually waste power with HHO.Electrolysis of water uses 2.0V at a high current, not 220V at a low current.HHO added to the intake of a car fools the pollution computer into making the gasoline mixture too lean which increases the fuel economy, increases NOX pollution and burns valves and pistons. Quote Link to comment Share on other sites More sharing options...
