Silent Jack Posted May 22, 2010 Report Posted May 22, 2010 I have a capacitor bank of 6x 400V 470uF capacitors in series parallel (2 wide, 3 deep) that I'd like to charge from a LIPO battery pack (most likely 12-14 volts). Can someone help me with the basics of designing a power supply? Quote
pyrohaz Posted May 24, 2010 Report Posted May 24, 2010 Hi Jack, when I was creating my capacitor bank (8000uF @200v) I was looking for a charging circuit and came across this website: http://sites.google.com/site/uzzors2k/boost_converterIt uses some quite simple components (555 timer, power mosfet and inductor) and as it says on the website, can charge his bank up in 30 seconds. Hope it helps :) Quote
Silent Jack Posted May 26, 2010 Author Report Posted May 26, 2010 Hey pyro, thanks for the link. It is interesting, and covers some points that I hadn't been able to find good info on so far. Your bank has some hefty capacitance, what are you using it to drive? Quote
pyrohaz Posted May 26, 2010 Report Posted May 26, 2010 I was originally going to use it to power an ETG gun but after having some extreme switching problems :P (couldn't find a thyristor or switching device with anywhere near enough current capability) I scrapped the idea and used the capacitors for different projects. Thanks to one of the users on this website, I picked up a load of them B stock off Rapid, I was really happy with the results and got some MASSIVE bangs out of creating molten flying aluminium sparks :P Quote
Silent Jack Posted June 8, 2010 Author Report Posted June 8, 2010 Phooey, had to redesign my project a bunch. Still a lot I'd like to learn about the basics of power supplies, particularly operating off of a battery pack. Can anybody suggest a good resource for learning/researching about these, or better still anyone with experience that can share? Quote
Silent Jack Posted June 22, 2010 Author Report Posted June 22, 2010 Inductors vs TransformersI've heard both terms used. Are they the same thing, different classes of something or simply a vernacular thing?555 vs other power regulating ICs pro's and cons? Quote
Hero999 Posted June 22, 2010 Report Posted June 22, 2010 Inductors vs TransformersI've heard both terms used. Are they the same thing, different classes of something or simply a vernacular thing?Look it up on Wikipedia.555 vs other power regulating ICs pro's and cons?A 555 is not a regulator, it's an oscillator, you could use any IC which can be configured as an oscillator and will work up to the required frequency. The op-amp is the part which performs rough regulation by disabling the 555 oscillator when the voltage is too high. Quote
Silent Jack Posted June 22, 2010 Author Report Posted June 22, 2010 I see you are highly rated HERO. In a supply for a 400V 970uF capacitor bank powered by either a 12V or 14.8V battery, is there a particular IC that you would recommend? Also, what is the best way to determine what ratings of other components are needed. I have already obtained a few low level calculators and have been pouring over a host of equations trying to work various conversions backwards to obtain some needed values. Perhaps your experience might suggest some? Quote
pyrohaz Posted June 22, 2010 Report Posted June 22, 2010 Hey Jack!I suppose one of the main points on the charge rate would be the battery capacity/chemistry type of the batteries. For example, the internal resistance of standard ni-mh batteries usually limits them (safely) at 3C, 3 times the capacity of the battery. For example, 1.2v at 800mAh would have a maximum output current of 2.4A with a voltage dropping proportionally. I think that if you try to charge the capacitors at a current of 1A to 1 time constant (63.2% charge) at 1A it would take about 6.4 minutes (T=RC, T(ms) = R(ohms)C(uF) 1A at 400V is a resistance of 400R, 400R x 970uF = 388000ms OR ~6 minutes)Unless you don't mind the quite long wait (if I worked that out correctly! XD) I think you will be in for designing quite a high current switching circuit. Even at 4A, the charge time will be 1.6 minutes for every time constant. Quote
Hero999 Posted June 23, 2010 Report Posted June 23, 2010 If it's constant current then the voltage ramps up linearly.A 970 Quote
Silent Jack Posted June 23, 2010 Author Report Posted June 23, 2010 Does it make any difference that they are two 400V 470uF capacitors in parallel? Quote
Hero999 Posted June 24, 2010 Report Posted June 24, 2010 Does it make any difference that they are two 400V 470uF capacitors in parallel?I've given you enough information to answer that yourself. Quote
Silent Jack Posted June 24, 2010 Author Report Posted June 24, 2010 I see the 555 has 3 different modes. Looks like this application calls for it to operate in the Astable mode. Is the purpose of the oscillation to create a particular wave form or is it for pulse generation? Also does it inherently create a given frequency in this mode? One of the calculators I have includes frequency as part of the equation, and you mention it as well. Quote
Hero999 Posted June 24, 2010 Report Posted June 24, 2010 Yes, the 555 generates when operating in astable mode.The inductor needs to be pulsed on and off to generate high voltage pulses for the back EMF to be generated. The frequency will depend on the current, the inductance and input and output voltages. You should not think of the frequency but the on and off times.Have you read the Wikipedia article on boost converters?http://en.wikipedia.org/wiki/Boost_converter Quote
Silent Jack Posted June 25, 2010 Author Report Posted June 25, 2010 I'm finally beginning to isolate some of the specific components based on a shared schematic I found online slowly adapting it to my specific application. As I figure it out, I plan to ask more specific questions in an effort to optimize the design for my application. One question that has definitely come to mind is do any of you know a good IC for switching a device like this via a PC or microcontroller, such as an arduino? Quote
Silent Jack Posted June 30, 2010 Author Report Posted June 30, 2010 What are peoples' feelings on IGBTs vs MOSFETs in SMPS applications?Also, I figure I can control device activation with a lower voltage/amperage switch in front of the battery, but what about the actual capacitor bank discharge control? I'd like to be able to control it from a microcontroller or PC. Any recommendations on this segment. Quote
Hero999 Posted June 30, 2010 Report Posted June 30, 2010 As far as controlling it from your PC is concerned a parallel port can be used with no MCU - it's fairly easy to set bits high and low.Unfortunately parallel ports aren't very common on new PCs so you'll need to use USB which requires an MCU but I can't help you with that.MOSFETs are better at lower voltages, IBGTs are better at higher voltages, of course I'm talking about the voltage actually switched by the transistor, i.e. the input, not the output voltage.Here's a few articles I've found:http://www.irf.com/technical-info/whitepaper/choosewisely.pdfhttp://en.wikipedia.org/wiki/Power_semiconductor_devicehttp://electronicdesign.com/article/components/igbts-or-mosfets-which-is-better-for-your-design-7.aspx Quote
Silent Jack Posted June 30, 2010 Author Report Posted June 30, 2010 Is it better to use an overated component or should they match more closely? (For example: My circuit will likely operate at 400V and 5-6A or so, should I use a 400V 5/6A MOSFET or IGBT, or would it be better to use say a 500V 10A model?) I prefer to make things as efficient and durable as possible, but must also maintain a low price. Quote
Hero999 Posted June 30, 2010 Report Posted June 30, 2010 I thought you said it ran from 12V to 14V?Using a higher voltage rating is fine but you'll find that MOSFETs with a higher voltage rating will have a higher on resistance. Quote
Silent Jack Posted July 1, 2010 Author Report Posted July 1, 2010 Its supply is from either a 12V or 14.8V battery, I'm leaning towards the 14.8V. The capacitor bank that the PS is supposed to charge is 2x 400V 470uF capacitors in parallel for 400V 940uF. Am I misunderstanding, I thought the PS MOSFETs/IGBTs would need to match the capacitor voltage, do they instead need to match the battery? Or rather are there different segments? They are for switching, correct? Quote
Hero999 Posted July 1, 2010 Report Posted July 1, 2010 It depends on the circuit, look at the maximum voltage across the MOSFET. Quote
Silent Jack Posted July 13, 2010 Author Report Posted July 13, 2010 I have a circuit diagram that I've been working off of to modify to meet my requirements. Would that be helpful to post as far as discerning things? Quote
Hero999 Posted July 13, 2010 Report Posted July 13, 2010 Look at the voltage across the MOSFET when it's in its off condition and it will give you an indication of the maximum voltage rating.For example in a typical boost converter the maximum voltage across the switch (MOSFET, BJT, etc.) is no more than the input voltage.http://en.wikipedia.org/wiki/Boost_converter Quote
Silent Jack Posted July 13, 2010 Author Report Posted July 13, 2010 The attached picture is of the diagram I am lableling pertaining to the modifications I am making so far. It is incomplete. I am still translating and adjusting. I have to give credit to the design's author rwilsford, who shared it. I have been cross referencing with other open and basic designs, along with datasheets to adapt it. Sadly, there still is a good bit I feel I don't understand as well as I should like. Quote
Hero999 Posted July 14, 2010 Report Posted July 14, 2010 It looks pretty straightforward and uses the same topology as the circuit from Wikipedia, I posted above.The 555 acts as an oscillator which runs until the required voltage is reached and is shut-off by the comparator. The shut down occurs when pin 4 is taken to 0V, which happens when the voltage on Rdiv2 is greater than the voltage on VR1.I'd probably consider removing the 555 and using the spare comparator on the LM393 as the oscillator.Why use JPG for schematics? It's designed for photographs and is lossy so goes fuzzy after a few saves, especially if the quality is set low. You should use PNG or GIF for drawings. I've converted your schematic to a PNG and removed the fuzz. Quote
