Sukhbinder Posted May 28, 2010 Report Share Posted May 28, 2010 Hi Guys, i have been using a 25W Solderon soldering iron for the past 15 years. i used a fine chisel tip with it, earlier i have been working with normal PCBs, but now since most of the PCB now have become more of SMD type and are much smaller in size, i am planning to get a new temperature controlled soldering iron. We have a distributor of goot products here. I tried finding about weller but no body stock them here due to high prices and less users for such quality tools. Actually there are a lot of cheap Chinese products available here at much lower prices. I found three models from goot, one is Mini-Soldering Stations/ Soldering Controllers PX-501, PX-601 with a power of 80W and temperature range 250-450C (i'll go for the PX-501 as the only additional feature in PX-601 is that the temperature control knob is covered with a protective cover and it has facility to measure leakage current and insulation resistance but i can do without these). both these models are available in antistatic versionsThe second is a Temperature Controlled Soldering Iron PX-201 with a power of 70W and temperature range 250-450C with a ceramic heater. the temperature setting knob is on the soldering iron itself. however it is not an antistatic product.The third is a Precision Assembly Soldering Iron PX-251AS with specs same as the second one but is an antistatic version and does not have the temperature control on the Iron but in a separate supply as the first PX-501 and PX-601.Although my trusty old 25W solderon iron still works and i have a hot air analog ( the air flow rate and heater can be set by knobs but no digital display) soldering/desoldering station also, if i buy a new temperature controlled soldering iron, which would you guys recommend from the above three choices and is it worth paying the extra for antistatic products? Quote Link to comment Share on other sites More sharing options...
