exodia Posted June 8, 2010 Report Share Posted June 8, 2010 Hello there and nice to find you guysI want your help into making a start studying photo voltaic system. The department i work is starting making studies about LED street lighting that will be power by PB panels, so i need something to startCan we make a talk on what to watch out for, what panels to use in proportion with the DC loads i got, and stuff like thatIn the application we will not use inverters, the DC will supply the LED circuits Quote Link to comment Share on other sites More sharing options...
chromei386 Posted June 8, 2010 Report Share Posted June 8, 2010 Some key issues I see arising are: How many LEDs and what type will it take to provide adequate lighting (if these are for replacements for normal street lights). What is the lighting requirement, is there any benchmark? What is the power drain? How will you store the energy - SLA batteries? NiMH? NiCd? How long will they be able to provide lighting at load requirements?What are your weight requirements? (Large SLAs are heavy, and could pose a danger if up high). What is your backup plan, if there is no sun for days. Do you feed from the grid? Quote Link to comment Share on other sites More sharing options...
Hero999 Posted June 8, 2010 Report Share Posted June 8, 2010 It depends on what kind of streetlighting system is already in place. It could be possible that LEDs are inferior to the existing system, for example I know that low pressure sodium lamps are the most efficient light source known and that LEDs are much less efficient. There again, I think that doesn't account for the fact that the dark adapted human eye is more sensitive to shorter wavelengths so I can't be sure. Quote Link to comment Share on other sites More sharing options...
exodia Posted June 17, 2010 Author Report Share Posted June 17, 2010 Hello again sorry for the delayed response@chromei386Power drain depends, thats why i want to be able to make some studiesWe will store energy at gel batteries and we need them for 3 days reserve. About 9 hours a dayNo feed from the grid ATM Quote Link to comment Share on other sites More sharing options...
