Hero999 Posted June 16, 2010 Report Share Posted June 16, 2010 I came up with this circuit yesterday, it's basically an h-bridge and astable multivibrator in one.I've not actually built it yet but LTSpice says it works all the way down to 0.9V, making it ideal for single cell operation. The saturation loss for both transistors ranges from 184mV to 224mV as the supply voltage is varied between 0.9V to 1.5V. The output waveform is not perfectly square and the RMS value ranges from 715.4mV to 1.278V as the supply voltage is varied between 0.9V to 1.5V so the power in the speaker will range from 64mW to 204mW. The cirucit won't be very loud but should be fine for simple indicator applications and is certainly louder than a half bridge which would give an estimated 40mW to 120mW over the range of 0.9V to 1.5V.The current consumption is 103mA to 216mA over the supply voltage range of 0.9V to 1.5V.The frequency ranges from 1.72kHz to 2.36kHz as the supply voltage is varied between 0.9V and 1.5V and can be altered by changing the values of R3, R4 and C1 and C2 but the resistor values stillneed to be low enough to ensure adequate base drive.The transistors are BC338 and BC328 for NPN and PNP respectively.I'll test the circuit but testing at voltages below 1.25V will be difficult for me as I only have an LM317 based PSU.My local supplier sells 1.5V buzzers but the datasheet gives a minimum operating voltage of 1.3V and the current consumption is only 25mA so they won't be anywhere near as loud as my circuit.http://www.rapidonline.com/netalogue/specs/35-0085e.pdfThis circuit can be used to drive a piezo sounder but the resistor values will need to be increased and C1 and C2 decreased. Quote Link to comment Share on other sites More sharing options...
Hero999 Posted June 29, 2010 Author Report Share Posted June 29, 2010 I've just tested it today and it works quite well. It sounds similar to a piezo buzzer. It's quite loud considering it's only running off a single AA cell, though I don't have a sound meter so it's pretty subjective.I varied the supply voltage between 0.944V to 1.54V and the frequency drifted from 2.07kHz to 2.67kHz which is higher than expected and is probably because the capacitors are slightly below their rated value, probably because they're old.I didn't manage to measure the current, it doesn't work when my current meter is connected in series with it, probably because the voltage drop is too high which is proof that the cheap meter is no good, the current war 66mA but it didn't oscillate. I'll connect another DVM to it and increase the voltage until it works, then measure the current.EDIT:I've managed to measure the current. I connected a 1 Quote Link to comment Share on other sites More sharing options...
