Jump to content
Electronics-Lab.com Community
Linear response
Kevin Weddle
Most designs employ a large number of components and they generate a lot of noise. But error correction is linear in most cases. If a circuit is going to incorporate a microprocessor, why are smaller circuits limited to simple, linear error correction? A voltage regulator IC, a phase lock loop, an opamp circuit or any other feedback circuit never seems to be logic controlled.
Link to comment
Share on other sites
Logic control is on and off. If it detects that the output voltage is too low then it can switch on full power until the voltage is high enough, then switch off. The output will be continuous waves of voltages.
A linear error correction circuit has an opamp as its error correction amplifier that has a very high voltage gain and makes subtle or drastic corrections. The opamp has a small delay which causes the output voltage to have undershoot and overshoot but is stable and accurate for most of the time.
Link to comment
I don't believe linear control is unreliable. But a signal that is produced by logic control can poroduce a more time sensitive response. Microprocessors generate at the the nanosecond. So as far as audio goes, it's much more of a higher frequency than that.
Maybe a high frequency expert can explain as to why a high a frequency circuit can't be used in lower frequency applications.
Link to comment
Perhaps he is seeking to remove noise from what he feels is an overly elaborate circuit by using a microprocessor which, theoretically would be able to smooth things out by responding more quickly.  Much like generators in cars were replaced by alternators in 120 degree phase to smooth out the fluctuations.  Just a thought.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
