walid Posted October 31, 2010 Report Share Posted October 31, 2010 Hi when i want to design a preamplifier using BJT and need to have a maximum symetrical voltage swing at the output, then two conditions must be satisfied:1- VCE = 0.5 VCC2- I (saturation) = 2 ICIs there other conditions must be taken into acount? Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted November 2, 2010 Report Share Posted November 2, 2010 Approximately .5Vcc is the optimum collector voltage for maximum voltage change. A bipolar transistor can however drop as much as .3 volts, which means the collector voltage would need to be .3volts higher. Quote Link to comment Share on other sites More sharing options...
walid Posted November 2, 2010 Author Report Share Posted November 2, 2010 VC or VCE? Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted November 2, 2010 Report Share Posted November 2, 2010 A saturated bipolar transistor can have a voltage of .3volts. That is VCE. VC, or colector voltage would be .5Vcc + .3volts. But normally, the saturation voltage is near 0volts. In biploar transistor digital logic, the maximum logic low level is .8volts. Quote Link to comment Share on other sites More sharing options...
audioguru Posted November 3, 2010 Report Share Posted November 3, 2010 A transistor needs an emitter resistor to add some negative feedback so its output is not extremely distorted and non-symmetrical, and so that transistor Vbe differences and temperature changes do not mess up its biasing. Then the emitter resistor has voltage across it which reduces the output swing and requires the operating point to be higher. Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted November 11, 2010 Report Share Posted November 11, 2010 I'm sorry, that formula is not correct. But the collector voltage is increased because of the saturated transistor voltage drop, if any, and the emitter resistor. Quote Link to comment Share on other sites More sharing options...
audioguru Posted November 11, 2010 Report Share Posted November 11, 2010 A single transistor with a high voltage gain produces an extremely distorted signal if its output approaches anywhere near cutoff because its transconductance is very non-linear.Here is an example: Quote Link to comment Share on other sites More sharing options...
