Jump to content
Electronics-Lab.com Community
Need help for motor driving with triacs
mesuthh
Hello people;
I really need help friends
I am tring to drive a single phase (230V AC) motor 4A with BT137(8A), but triac gets hot like 35 celcius degree (even I am using cooler) and after some switching it is getting failed. So that later on I have changed the triac with BTA41(40A) and heatshink, but it is still hot around 30 degree, and in one week BTA41 also gets failing. I am tring to drve the triac with Moc3041, and I am tring to switching the triac when 5Vdc available on Moc3041.
I have tried to use snubber but it is not solving the problem
you can reach the view of my circuit on
here I am triying drive the motor with 5V dc control to moc3041 so triac fries and the motor starts, and one more think I am also drving a 25uf 400 V capacitor (paralell with the motor) with that motor for compansating
if someone has an advice I will be really thankfull to him/her
Regards
Link to comment
Share on other sites
  • 10 months later...
  • 4 months later...
http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/93323-switching-ac-loads-triac.html
I think the resistor is too small needs to be 330
BT137 Datasheet
http://www.nxp.com/documents/data_sheet/BT137_SERIES.pdf
BTA41
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00002263.pdf
Moc3041 Datasheet
http://www.electro-tech-online.com/custompdfs/2009/05/moc3041.pdf
Link to comment
  • 1 month later...
  • 2 years later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
