kbyrne Posted January 28, 2011 Report Share Posted January 28, 2011 I need assistance with two transistors and info if data sheets are available.1. MJE3055 Data sheet and MJE3055T Data sheet to see if they are interchangeable.2. MJE2955 Data sheet and MJE2955T Data sheet to see if they are interchangeable.One other part a IC1. L165 DATA sheet and L165H Data sheet to see if they are interchangeable.tanks kbyrne Quote Link to comment Share on other sites More sharing options...
audioguru Posted January 28, 2011 Report Share Posted January 28, 2011 I get datasheets from www.datasheetarchive.com . I can select a manufacturer.A 2N3055 is in a steel case and has a max allowed internal temperature of 200 degrees C.An MJE3055 is in a plastic case (T) and has a max allowed internal temperature of 150 degrees C.Their max allowed currents are also different. Quote Link to comment Share on other sites More sharing options...
george.brooks Posted February 17, 2011 Report Share Posted February 17, 2011 n OUTPUT CURRENT UP TO 3A L165H data LARGE COMMON-MODE AND DIFFERENTIAL MODE RANGESn SOA PROTECTIONn THERMAL PROTECTIONn Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted February 22, 2011 Report Share Posted February 22, 2011 In most cases they are interchangable.L165 Datasheethttp://www.eng.yale.edu/ee-labs/morse/compo/datasheets/1317.pdfMJE3055T Datasheethttp://www.fairchildsemi.com/ds/MJ%2FMJE3055T.pdfhttp://www.onsemi.com/pub_link/Collateral/MJE2955T-D.PDF Quote Link to comment Share on other sites More sharing options...
kbyrne Posted April 29, 2011 Author Report Share Posted April 29, 2011 ;D Tanks again I have the data althou I can not find a l165h part source yet. Any ideas about thermistors and a Icl7107. the gage goes down with a 1kthermistor and a 100ohm ntc thermistor and is supposed to go up instead. by. see ya. Quote Link to comment Share on other sites More sharing options...
