Jump to content
Electronics-Lab.com Community
resisitor value
protech
Hi
Could anyone advise on the value this resisitor?
It looks like it has failed as it is open circuit when testing
it so I can not measure it's resisitance and i do not have any
access to the circuit diagram.
www.earthspike.com/jv.jpg
The colours, which look fadded, seem to be:
WHITE : BROWN : BROWN : RED : SILVER
or it could be
WHITE : ORANGE : ORANGE : RED : SILVER
any ideas on what value it is so I can replace it?
also does the colour of the resistor body (blue/green) have any significance?
Cheers
Link to comment
Share on other sites
Could it be grey, red, gold, gold, white?
It isn't clear.
It's probably a fairly low power resistor.
Read the code as per the chart below, then bear in mind the value is most likely to be a standard E24 or E96 value or at least a round value, otherwise it's unlikely to be correct.  I'd hazard a guess that it's a fairly low value given its size and how it's mounted a fair distance from the PCB. It looks like the designer has undersized the resistor so replace it with one with a higher power rating.
http://en.wikipedia.org/wiki/Preferred_value#E_series:_Capacitors_and_resistors
Link to comment
  • 3 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
