GettingOld Posted March 2, 2011 Report Share Posted March 2, 2011 Simple problem - I need to control a digital IO from Linux - preferably using an USB interface.I was going to use a MSP430 Launch pad, but the CDC serial support with Linux is not reliable. I am planning on using a TI RF2500 with the built-in application UART next but it is a little pricey ~$50.00.The goal is to control a digital relay which will in turn be used to power cycle an unreliable piece of low-voltage equipment.I need nothing more than to be able to assert an IO, wait for a bit, and then send a character back to the host application.I'd appreciate any pointers to low-cost, readily available solutions. I'm in Canada, so things I can get from Digikey would get preference. Quote Link to comment Share on other sites More sharing options...
gogo2520 Posted March 4, 2011 Report Share Posted March 4, 2011 Hello gettingold Problrm with linux is permissions, exspecail with USB ports.there is some stuff on the net for work arounds but you might have better luck using a microchip mcu instead. gogo Quote Link to comment Share on other sites More sharing options...
