nexus_2006 Posted March 7, 2011 Report Share Posted March 7, 2011 Hi all, first post. I need help designing a voice storage system. I want to store about 5 short messages (less than a minute in most cases), and be able to play them back. I am trying to find a decent IC that can do this, but am not having any luck finding something readily available. The goal is to be able to listen to a voice-band radio and store the 5 most recent for playback. I'm thinking the "click" of the microphone keying up would make a fine "start and stop recording" trigger. It would also need to be able to throw the oldest message out to free up space for newer transmissions. This is likely least complicated with a dedicated microcontroller that can be programmed by PC or something, rather than discreet components. Attached is the concept block diagram. Any help at all would be appreciated. Quote Link to comment Share on other sites More sharing options...
KMoffett Posted March 8, 2011 Report Share Posted March 8, 2011 Check these segment addressable recorder/playback chips:http://www.nuvoton.com/hq/enu/ProductAndSales/ProductLines/ConsumerElectronicsIC/ISDVoiceIC/ISDChipCorder/Pages/default.aspxKen Quote Link to comment Share on other sites More sharing options...
pdp Posted March 9, 2011 Report Share Posted March 9, 2011 In my opinion, it could make some sense if only the goal was to build a special featured device. Othewise it would just have to compete with great amount of those inexpensive factory-made voice recording gadgets that are easily available now. Quote Link to comment Share on other sites More sharing options...
kxenos Posted May 23, 2011 Report Share Posted May 23, 2011 My suggestion is: Use an ARM uC to capture, encode and store the signal into an external eeprom. Use an open source speech codec like SPEEX which is perfect for encoding speech with excellent quality into bitrates of 2kbps, 4kbps etc. With 8kbps you will have perfect results. With 8kbps audio bitrate, if you want to store 5min of audio you need 5min * 60sec = 300sec. 300sec * 8kbit/sec = 2400kbit or 300KB of data. Take a look at ST micro cortex M3 which is STM32*. There is an application note that does exactly that. It has the audio circuit around the uC for line input and line output. OLIMEX has a dev. kit that has implemented exactly this circuit. So all you have to do is load the code from ST and off you go. You don't even have to do a prototype for proof of concept. App. note.: http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/APPLICATION_NOTE/CD00204907.pdfdev. board: STM32-103STK link: http://www.olimex.com/dev/pdf/ARM/ST/STM32-103STK.pdfYou will also have to use an external memory for the messages. The dev board has an SD/MMC connector so you might as well use this resource. Extra feature: Voice messages could be transferred into laptop or other device via sd card if you implement a known file system like FAT16.Hope I helped. Just registered today, so I'm excused for the delay, right? :-) Quote Link to comment Share on other sites More sharing options...
ARUN CHOWDARY Posted June 14, 2011 Report Share Posted June 14, 2011 it is a very easy design use a high sensitive microphone and amplify the signal by using a power amplifier store it in a memory device use computer for it or any interface recorder Quote Link to comment Share on other sites More sharing options...
Herman the German Posted June 28, 2011 Report Share Posted June 28, 2011 Hi nexus_2006,you might want to try this circuit.It is built around an ISD2532 (32seconds at 8KHz sampling frequency). If that one won't suffice you might select an ISD2564 (64seconds).The device can be controlled locally and via a microcontroller. All necessary connections are available at SV2.Remark: The mic connects via two pads. However if a mic with built in Fet-transistor is used polarity may be changed turning the mic 180degrees.If you are interested in the Eagle files leave your full name and email address in a PM.RegardsHtG Quote Link to comment Share on other sites More sharing options...
