eplanet Posted May 3, 2011 Report Share Posted May 3, 2011 hi friendshave you any idea for sending data (0 or 1) with laser diode to receiver diode with PIC micro controller and indicate to LCD 2*16 characterize lcd??thanks Quote Link to comment Share on other sites More sharing options...
eplanet Posted May 7, 2011 Author Report Share Posted May 7, 2011 i have laser pointer (use in presentation) and i want to transmit data up to 1meter (zero and one logical method ) , with receiver sensor. for first in this issue i need circuit for amplify signal (fast switching) in receiver. look at this schematic !!i know how can i make signal in transmitter with micro controller but i have problem with using 2pin receiver sensor.if you have any idea for amplify signal in receiver circuit? Quote Link to comment Share on other sites More sharing options...
Hero999 Posted May 7, 2011 Report Share Posted May 7, 2011 Have you Googled?As it only neds to transmit over 1m why not drop the laser idea and use a standard IR LED and remote control receiver IC? Quote Link to comment Share on other sites More sharing options...
ARUN CHOWDARY Posted June 14, 2011 Report Share Posted June 14, 2011 yes perfectly you can transfer data from laser pointer up to 10 meters also by using the laser of low beam width by using the high response devices in the receiver circuit you can achieve high speed and by using high gain amplifier you can raise the level of the output to the peak level in the transmitting stage the program for converting the asii to binary is needed you should use the keyboard interface by the RS 232 socket by giving input in ASII code it will convert into binary digits then the output is connected to the laser Quote Link to comment Share on other sites More sharing options...
