karthikeid Posted June 18, 2011 Report Share Posted June 18, 2011 hithis is the circuit i did, but nothing seems to be working only the backlight is glowing oni have constructed the PDIP version of this which was posted athttp://elfly.pl/multimetr/multimetr_en_DIP.htmhttp://www.electronics-lab.com/projects/test/007/index.html Quote Link to comment Share on other sites More sharing options...
Scooter_3D Posted June 19, 2011 Report Share Posted June 19, 2011 Did you set the correct fuse settings before uploading the code ???It is assumed here, that Quote Link to comment Share on other sites More sharing options...
redwire Posted June 20, 2011 Report Share Posted June 20, 2011 This is tough project for a first timer to get a LCD going on. I know this from personal experience. There are so many things that can prevent a successful project. First did you get confirmation that the IC was successfully loaded with code? What hardware did you use to program? Are your wires connected correctly, do you have any bad traces or shorts, did you adjust the pots for the lcd display(and check voltages) .......and so forth. The fact that you have nothing showing seems to indicate there is a problem with the IC or connections, because when the program first loads there are some text that should show up. The first step is to get something to show up on the lcd even if it's crazy characters. Quote Link to comment Share on other sites More sharing options...
