wiparat Posted August 27, 2011 Report Share Posted August 27, 2011 This is a review of electronic sound or a violent coin toss. With electronic circuits. This circuit uses integrated digital IC NE555 and CD4017 with LED display easily. Principle of the circuit, when voltage is 5 volts to the circuit C1 will charge through the VR1 and R1 fully. IC1, R2, R3 and C2 to the astable multivibrator circuit.Rectangular waveform generator (Square Wave) sent out to pin 3 of IC1, through the trigger. (Which uses the T-on of the wave is a signal of the trigger), the pin 14 of IC2. This is the pin input, causing the output to come out to pins 3, the LED1 light LED2 goes out. When the signal came. The trigger pin 14 more to have come out to the output pin 2, the light LED1 LED2 off. The switch will stick together and when a trigger signal to the pin 14 again, to start new But because the astable multivibrator circuit acts rectangular waveform generator (Square Wave) with high frequency, it seems that the LED1 and LED2 is illuminated at all times. When the switch S1 open circuit (Open Circuit) to C1 discharged out through R1, VR1, VR2, R2, R3 and C1 and C2 discharge completely. Make a circuit Stable multi-stop sensitivity Brett Foster rectangular signal generator (Square Wave), so we know that the LED lamps which display Quote Link to comment Share on other sites More sharing options...
Hero999 Posted August 27, 2011 Report Share Posted August 27, 2011 Why post another circuit which basically does the same thing?You don't even need a 555, it's possible to do this with a single CD4013 with one half configured as an astable. I prefer to use the modern 74HC74 though as it can drive LEDs brightly and run off a couple of AA cells. Quote Link to comment Share on other sites More sharing options...
wiparat Posted August 28, 2011 Author Report Share Posted August 28, 2011 Why post another circuit which basically does the same thing?You don't even need a 555, it's possible to do this with a single CD4013 with one half configured as an astable. I prefer to use the modern 74HC74 though as it can drive LEDs brightly and run off a couple of AA cells.Your idea are very good. Ic 74HC74 is small, but sure. Thank you. Quote Link to comment Share on other sites More sharing options...
Hero999 Posted August 28, 2011 Report Share Posted August 28, 2011 The 74HC74 is available in the same size DIL package as the old CD4013. Quote Link to comment Share on other sites More sharing options...
Hero999 Posted August 29, 2011 Report Share Posted August 29, 2011 Here's another simpler decision maker circuit. Quote Link to comment Share on other sites More sharing options...
